I hope I get this right?
Hi, it's Martin here from Pleiades.
Slim has been round and talked, well more nagged me into regestering to this forum, so I just tought that I would log in and say hello.
I will try to answer some questions on hydraulicy things when I get chance but I realy am a computor dinosaur, I havent a clue how or why computors work but I do realise that for some reason we cannot live without them (a bit like woman)
Most of my work these days seems to be on the DS hydraulic parts but I do as a general rule, anything that the green blood runs through.
I will try to log in as much as I can but especialy in the summer, being an outdoors type of chap, I like to spend my evenings out and my weekends in North Wales whenever I can, (Wales has the best kayaking rivers around)
What I do not realy want is to turn my answers into some kind of Pleiades advert as I don't think that this would be the correct way to go.
Finally, I have read a message here about the Pleiades web site being hacked, We had to disable the on-line shopping cart as people kept ordering the wrong part for their car and this caused problems, this forced us to disable the cart. I am hoping to get it sorted soon into an enquiry cart, then we can check the order and ensure that the correct part is sent out to our customer. Or even better, a new web site that I can maintain myself, but as a computor thiko this may prove difficult. In the meantime it seems to dissapear into some kind of search portal and ends up suggesting web sites that sell tractor pumps?
What Citroen do I drive? Well I do have a decent Xantia Estate 1.9 TD but I normally am seen driving around in a scruffy Mitsubishi L200 pick up, I know it's wrong but it is so handy and suits the lifestyle, I can throw all my kayaks and wet gear in the back, drive across fields with no fear of getting bogged down, but the Xantia is my weapon of choice if I want to be posh! Both run on about 80% cheapest veg oil I can get. I did have a Suzuki SJ 410 that I placed a BX turbo diesel engine under the bonnet, worked well but thats another story.
Well thats it for now, please go easy with me and maybe Slim will help me with any complications that I come across.
Cheers.
Martin. (Pleiades)
Hi From Pleiades
MikeT
- x 232
Hello Martin and welcome. Thank you for overcoming your technophobia, I look forward to your future posts. I would like to take this opportunity to thank your company for the prompt and informative reply I received when I had the one occasion to enquire about a pinion valve. Highly recommended.
Thanks also to Slim for guiding you here.
admiral51
- (Donor 2026)
- x 391
Hi and welcome to the asylum
its good in here honest
dont worry about any answers being an advert for Pleiades we can only answer questions based on knowledge,fact and in my case guesswork
i believe they have laptops these days that can connect to the internet so whilst your away in wales you can still be here with us
well done Slim
Colin
well done Slim
Colin
- x 8287
Hi Martin and a very warm welcome
You don't need to worry about advertising; we all know who Pleiades are on here
In connection with virtually any hydraulic query your name pops up. Your sphere removal tool is held in very high regard, it was the only one that would budge spheres on my Activa
Speaking of Activas, are you able to supply spheres for them or re-gas them?
ellevie
You are most welcome to the forum Martin ! It's great to have you here, your expertise on Citroen hydraulics must be unsurpassed. You are often mentioned on here and other Citroen forums as a valuable source of hydraulic parts, tools, hydraulic pipes and so on The Pleiades sphere removal tool has often been recommended and praised.
David
David
Penguin
Sorry to hijack the thread but I've just been to the website and do not see a sphere removal tool. What does it look like and how much does it cost? Cheers (this could have saved me some time, bother and money last week!)citrojim wrote:Your sphere removal tool is held in very high regard, it was the only one that would budge spheres on my Activa![]()
Penguin
- x 1240
steelcityuk
Pleiades
Hi All.
Well it's a great welcome, I usually run the computor in the morning, at luchtime and early evening, thats when I check the emails. So I guess that I will have to check here and see what is happening in the Citroen world.
Just to answer a few questions..
Mike.
Pinions are a popular item for us I just feel sorry for the chap who has to fit the dam thing.
Jim, Yes we can do the activa spheres, all 10 of them!! The activa uses as follows, although I expect that you already know this.
2 x Fronts
2 x Rears
1 x Main Accumulator
1 x Anti sink
1 x Front suspension accumulator
1 X Rear suspension accumulator
1 x Front active ride sphere
1 x Rear active ride sphere
The thing that I cannot help with is the enevitable leaking active ride rams, although this is a project on the back burner for when they become no longer available from Citroen.
Steve.
Glad to have helped with the pipes and allways nice to know when someone is pleased with the service. Sorry but I have not realy had an awfull lot to do with the C5 but I can help a little sometimes.
Colin.
I have a laptop, but have enough trouble trying to work it here in sunny Sawtry, let alone half way up Snowdon!
Slim,
Nuff Said!!!!!
David and Penguin.
The Band wrench has proved a very popular tool over the years, we developed it especialy for the CX fronts where the subframe prevents you getting a chain wrench around the sphere, I will try to post a photo later.
Peter.
I recognise the area, we have sent you a few bits and bobs of pipe etc, I know this as Wooton Fitzpaine is not too big, only has a couple of houses and when I was younger living in Bridport, my auntie lived in the other... I will look into club XM when I have got my head around this one!
Thats all for now, busy night tonight, thanks again for the very warm welcome and I will try my best to behave.
Cheers
Martin.
PS. What do the little yellow things do on the left, I see that jim has poped one over into his message, Magic maybe???
Mike.
2 x Fronts
2 x Rears
1 x Anti sink
Steve.
Colin.
Slim,
Nuff Said!!!!!
David and Penguin.
Peter.
Cheers
Martin.
JohnD
- x 72
Here's a picture of mine - taken to enable it to go on eBay. Great tool, but not the correct size for C5 spheres.Penguin wrote: I've just been to the website and do not see a sphere removal tool. What does it look like and how much does it cost?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- x 8287
Hi Martin,
Great news on the Activa spheres
and even better news that you have rams on the back-burner. It has always been a worry at the back of my mind that one day Activa rams would become totally unavailable.
Those little yellow things are called emoticons 8)
When composing a post, just click on the one you want to convey your feelings and it will insert it into your message. It won't look like a yellow thing until you submit or preview your post. In the text editor box where you type your message it'll just appear as a a random collection of letters and punctuation like this : D and then when you submit or preview you'll see
They are really quite good for conveying feelings without lots of typing. If you click the "View more Emoticons" link, you'll find a whole load more..
DickieG
- Monaco's youngest playboy
- x 38
The Pleiades sphere tool is a simple but very clever piece of engineering as the angle the ring is offset at seems to be exactly the right angle for every sphere I've removed, an essential piece of equipment for the hydraulic Citroën owner.
Hi Martin, good to see you on here at last, we met in Crete a few years ago, happy memories on that holiday of watching the World Cup Final in the open air quaffing the odd ale on a warm evening 8)
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
deian
nick
Hi Martin, nice to see you here and welcome to the forum!
In my days of owning BXs and a Xantia I obtained various bits for them from Pleiades, including a band wrench. Well, 2 band wrenches. I lent the first one to my neighbour who was so impressed with it he immediately moved house and took it with him
