How long should an air con regas last?
Post your Cit/Peu/Ren air conditioning queries or advice.
Bren
Unread post by Bren »
I had my system gassed in the summer of 2006, however last summer on our annual trip to Devon the A/C was non-existent. I have noticed a lot of frothing in the receiver dryer, so I assume that the system is empty. Any advice would be appreciated.
96'Xantia 1.9 td estate
93'gsxr- 750
85' Rover 3500 (work in progress)
slim123
Unread post by slim123 »
Approx 2 years is the reccomended re-charge period to keep it all working well, but if it has lost all the gas I would suspect a leak in the condensor (the rad in front of the rad).
The correct way to service aircon is to suck the system to a vacum, then hold it for about 1/2 hour and see if the gauge moves to test for leaks, then the correct amount of refigerent is pressurised in by weight.
BUT...........
I have found that the re-charge can from Halfords works well and it also contains a leak sealer, so if the leak is small it may well cure it.
Regards
Slim.
