C5 II radio removal, bluetooth and Ipod connector
GB
Unread post by GB »
What tools are required to remove the RD4 C5 II radio? Would a standard ISO radio removal tool do the job? The radio unit features only one hole on each side.
Also, apart from the standard Citroen USB Box ipod interface from my friedly local Citroen stealer (£249 installed, and not guaranteed to work with C5 radio) are there any other RD4 compatible ipod connector boxes worth checking out?
Cheers,
GB
05 C5 VTR 2.0 HDI
115k
x 1044
Unread post by wheeler »
its 2 torx screws in the holes, either T15 or T20 cant remember. you need a screwdriver with a thin shaft though to fit through the holes.
GB
Unread post by GB »
wheeler wrote:its 2 torx screws in the holes, either T15 or T20 cant remember. you need a screwdriver with a thin shaft though to fit through the holes.
Thanks! Just ordered a set on Ebay.
Cheers,
GB
05 C5 VTR 2.0 HDI
115k
pete_wood_uk
Unread post by pete_wood_uk »
Hi GB
I've just posted a new topic here, but it looks like you might be ahead of me.
I'm trying to fit an autochanger to a 2007 C5, which I think has the RD4 radio - dealer mentioned that - but couldn't give me manufacturer or model number, so www.addacdchanger.co.uk can't tell me if their Sony changer will work with my radio or not (I have loom and cradle pre-fitted under seat).
If you've had the radio out, can you help...?
Many thanks
Pete
Xantia HDi 110 Excl Estate 140k
C5 HDi 138 Estate
GB
Unread post by GB »
pete_wood_uk wrote:If you've had the radio out, can you help...?
Many thanks
Pete
Not yet. Doing it this weekend hopefully.
BTW, the required torx key is size 10.
Cheers,
GB
05 C5 VTR 2.0 HDI
115k
