Xsara II plip reset
keef1212
Xsara II plip reset
Unread post by keef1212 »
Hi all,
Since a temporary disconnect of the car battery my (3 button rf) remote plip won't operate the central locking. (Xsara II 1.4i 2002)
I have tried replacing the fob battery and following the instructions in the handbook to re-program..... ie, turn on ignition, press lock button for 10 secs, remove key, to no avail :(
Citroen say the code in the ECU must be lost - £65 to re-program (not for the transponder, the car starts fine).
I thought that the key programs the ECU for C/L, not the other way round ??
Is this a common problem ??
Any advice gratefully rec'd.
OzRX4
Unread post by OzRX4 »
Have had a similar problem with our Xsara 1998 1.8 key for a while now too.
It still works fine except for the remote function. The sensor in the key is OK too as the ignition warning still operates if the key is near the ignition lock. I changed the battery twice to no avail. :oops: :? :x
LIFE: the cost of living hasn't reduced it's popularity
2001 Renault Scenic RX4 2.0i
1998 Citroen Xsara 1.8i (auto...hers)
1969 Renault R10 's' replica(in progress)
nick
Re: Xsara II plip reset
Unread post by nick »
keef1212 wrote:Hi all,
Unfortunately it does seem to be a common problem on Xsara's, and the only solution is to get someone with the right computer (either a dealer or specialist) to plug it in and re-initialise it in the BSI. I had to have mine done a few months ago, it cost about £60 including getting the code from Citroen as the previous owner had lost the code card :(
In my case I think it was caused by someone (not me, long story!) disconnecting the battery terminal before the BSI had time to shut down properly.
nick
Just noticed how long ago the original post is from. :o
Hope he got it sorted!
keef1212
Nope, still got the car but just using the key.
Not gonna pay £65, so I'll live with it..... :(
Thx for the advice ppl :)
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
If you're anywhere near the west side of the M25 I'll do it for you.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
keef12121
Unread post by keef12121 »
Thx DickieG for ur kind offer of help.... :)
As u can see I have had to register again under a new name as I couldn't logon to reply after updating my email addy...... :?
I live in Croydon (would be worth the journey over), but I also don't have the code card (lost by previous owner), so I don't know if u can do it without that...
Would be nice to get the remote working again, but I've learned to live without it 8)
uncle buck
x 10
Unread post by uncle buck »
If your plip has stopped working & can't be reprogrammed without having to pay big bucks is it not worth buying a cheapish remote control car alarm that can be wired into the existing central locking!
Just have a look on ebay there's loads of them.
2001 Xsara II 1.4 LX
