xantia hydraulic pumps
toldem_oldham
Unread post by toldem_oldham »
My old xantia 1.9 td lx has pump problems its loosing lhm under the pump,now i presume its kaput so contacted breakers yards they say there is several types available, i mentioned its a mk2 with air con and they still say they cant say what 1 is the right 1 so how do i pick the right 1 is there a number on the body which helps this issue
02 c5 2.0 hdi sx estate
x 1238
Unread post by Peter.N. »
I think the only real differences are whether it has one or two outputs and the size of the pulley.
Take a photograph of it and take it with you.
x 694
Unread post by Mandrake »
Peter.N. wrote:I think the only real differences are whether it has one or two outputs and the size of the pulley.
If only. :roll:
There are also differences in the relative locations of the input and output pipes. (The angles around the pump where they're located) I remember Anders posting a list from pr.net of all the different Xantia pumps some time ago and there were a stupid number of variations. (About 6 not counting the older single output types, which had their own variations...)
Regards,
x 1238
I stand corrected :oops: I'm afraid I only know about XM's.
steelcityuk
Unread post by steelcityuk »
Hi,
This was Anders reply when I asked the same question -
Steve.
Pick one Surprised :
(only 2 port 6+2 piston types listed)
4007.T2 HIGH PRESS PUMP
- POWER STEERING AND WITHOUT AIR CONDITIONING UNTIL RPO No. 06444
- INJECTION XU5JP AND WITHOUT AIR CONDITIONING
- INJECTION XU7JP AND WITHOUT AIR CONDITIONING
- INJECTION XU7JB AND WITHOUT AIR CONDITIONING
- INJECTION XU7JP4 AND WITHOUT AIR CONDITIONING
- INJECTION XU10J2 AND WITHOUT AIR CONDITIONING
- INJECTION XU10J4 AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445
4007.T3 HIGH PRESS PUMP
- INJECTION XU10J2 AND AIR CONDITIONNING
- INJECTION XU10J4 AND AIR CONDITIONING
4007.T4 HIGH PRESS PUMP
- INJECTION XU5JP AND AIR CONDITIONNING
- INJECTION XU7JP AND AIR CONDITIONNING
- INJECTION XU7JB AND AIR CONDITIONNING
- INJECTION XU7JP4 AND AIR CONDITIONNING
4007.T5 HIGH PRESS PUMP
- DIESEL XU UNTIL RPO No. 06444
- DIESEL XUD9 AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445 UNTIL RPO No. 07260
- DIESEL XUD9 AND AIR CONDITIONING SINCE RPO No. 06445 UNTIL RPO No. 07260
- DIESEL TURBO XUD9SD UNTIL RPO No. 07260
- TURBO DIESEL XUD9TE SINCE RPO No. 06445 UNTIL RPO No. 07260
4007.T7 HIGH PRESS PUMP
- TURBO DIESEL XUD11BTE AND WITHOUT AIR CONDITIONING
- TURBO DIESEL XUD11BTE AND AIR CONDITIONING SINCE RPO No. 07445
4007.T8 HIGH PRESS PUMP
- TURBO DIESEL XUD11BTE AND AIR CONDITIONING UNTIL RPO No. 07444
4007.T9 HIGH PRESS PUMP
- TURBO INJECTION XU10J2TE
- INJECTION XU10J4R
4007.Y7 HIGH PRESS PUMP
- TURBO DIESEL XUD9TE AND AL4 (HP16) AND WITHOUT AIR CONDITIONING
4007.Y6 HIGH PRESS PUMP
- TURBO DIESEL DW10TD
- DW10ATED TURBO DIESEL
4007.Q9 HIGH PRESS PUMP
- INJECTION ES9J4
_________________
Anders (DK) - '91 BX16meteor & '90 BX16RI.Est
not applicable
x 1238
Good grief! :?
toldem_oldham
Looks like take it off and take it to gsf for exchange pump instead of risking a wrong pump or a defective 1 thanx all :)
steelcityuk
Have you tried Pleiades to see how much they charge for a recon?
http://www.citroen-hydraulics.com/
Good luck with it.
Steve.
not applicable
AndersDK
Unread post by AndersDK »
You may try dismantle the pump. Contrary to the earlier types this is very easy. Any O-ring/seal you find is available as spare - or included in a kit.
These new generation pumps are surprisingly simple internally. Nothing like the earlier multi-piston pumps.
Anders (DK) - '90 BX16Image
toldem_oldham
Where can i get these pump kits from? does gsf do them or main stealers
AndersDK
toldem_oldham wrote:Where can i get these pump kits from? does gsf do them or main stealers
Main stealers only.
4026.86 01 O-RING 44.2T3
- DIESEL XU
4026.87 03 O-RING DIAM 16-TO 1.9
- DIESEL XU
4026.88 03 O-RING DIAM 19-TO 2.4
- DIESEL XU
They are some 1-2 quid each. Note you need 3 each of the 2 types listed, for a full set. There is not to my knowledge a complete set. You will need the 3 part no. listed.
These O-rings are valid for all later style pump types.
Be careful dismantling the pump such the pump body bolts are unscrewed little by little to prevent stress. Otherwise there is a risc the bolts will snap.
On re-assembly, the bolts should be torqued equally in steps, sensible according to size and thread gauge. There is no info on the torque setting.
toldem_oldham
Thanx anders i will give them a try monday
andmcit
x 30
Unread post by andmcit »
Andrew
x 694
Main stealers only.
- DIESEL XU
- DIESEL XU
- DIESEL XU
Actually thats not correct Anders, for a 6+2 two output pump you'll need the following:
One of 402686 - this is a large square section seal which seals the end cap where the power steering output comes out.
Six of 402687 - these are small green o-rings for the 6 pistons that provide for the power steering - they are under the torx head bolts.
Two of 402688 - these are the slightly larger black o-rings for the two pistons that provide for brakes/suspension - one under the steel pipe output that goes to the regulator, the other under the 19mm hex head bolt.
Furthermore there is another large o-ring seal between the main pump body and the triangular end plate that supports the pulley, and this is NOT provided by Citroen, but as luck would have it, a normal square section sphere neck seal is a perfect fit. :lol: This is the only seal not available from Citroen which is used in the pump. :evil:
Here's a picture of my old pump when I had it apart for new seals (and you can see the sphere neck seal sitting in the grove on the pulley section):
http://homepages.igrin.co.nz/simon/imag ... ppump1.jpg
I would offer some further warnings - the torx head bolts for the power steering pistons are EXTREMELY tight, and they cannot be undone with the pump body simply clamped in a vice, there are no suitable faces where you can grip the pump tightly enough without doing damage to the housing.
I was unable to get any of them undone with the facilities I had which included a proper torx bit with a 3/8" drive and a large vice, always the pump was trying to twist in the vice. The only way I could see of doing it would be to make a bracket that bolts to the pump in the same way as the original bracket on the car.
I'd also suggest not replacing any seals that aren't leaking (IMHO) and make sure to use the original Citroen types.
In my pump one of the black seals on the 2 piston section (the rear one with the blank hex head bolt) started leaking and the local replacements I found which looked almost exactly right all started leaking again within days because they weren't quite the right size or consistency - finally I got citrojim to post me over a few genuine citroen ones and they have been perfectly ok. (Thanks Jim :) ) So don't skimp on the quality of the seal :)
Regards,
AndersDK
Cheers Simon 8)
Nice seeing you are back again as ever ... :lol:
