Xantia Softer Spheres
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Update; Having soldered in new VN05N's to the duff ECU it now appears to be working again :D . I've only plugged it in with the car stationary but opening a door activated the electrovalves which it wasn't doing before. I'll carry out further testing over the weekend and report back.
For those interested I bought the VN05N's from Ebay, £2.30 each + £1.95 p+p.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8125
Excellent news Richard :D
x 694
Unread post by Mandrake »
citrojim wrote: I reckon on your MK2 you should be able to fool the ECU by putting a short circuit in place of the switch. Although that begs the question of how the HA ECU knows when to pop the suspension into hard on heavy braking. I guess it does it by calculating the rate of change of speed from the VSS :?
Yes, I do wonder about that.
One of the rules even in the MK1 Xantia ECU calculates deceleration based on the change in measured road speed, and if the deceleration is more than a certain amount it will trigger a switch to hard mode - presumably this is a backup in case of failure of the brake pressure switch.
If they've decided to do away with the brake pressure switch in the MK2 and rely just on the deceleration measurement, I'm disappointed - thats just plain stupid - it takes time to measure deceleration as it is not instantaneous - so the suspension will already have dived BEFORE it switches to hard mode.
With the brake pressure switch the reaction to hitting the brakes is so fast that it switches to hard mode BEFORE deceleration and thus prevents the car from diving in the first place.
The problem with the failsafe mode is that if the switch remains open circuit the ECU is too dumb to figure this out properly - and you get that situation described where it keeps switching into hard mode most of the time above 25Km/hr - and it takes a lot of driving for it to figure out there is a fault and go back to soft mode, and then when you slow down and drive off again it has to figure it all out again. :evil:
Although I haven't tried it, I think a temporary workaround of replacing the switch with a short circuit (instead of open circuit) should work - a short corresponds to no braking, so it will stay in soft mode most of the time as it should, and you have the backup rules that measure deceleration for a switch to hard mode.
(It also uses rapid deceleration and no change in the brake pressure switch as a sign that the brake pressure switch is faulty, so it will then start ignoring it anyway)
You could maybe fit a switch. It, I believe, sits in a "K" junction in the front brake feed line under and behined the LHM reservior.
I'm curious now. I was always pretty sure my MK2 Activa had the brake pressure switch. I'll have a closer look when I can but it's not easy to spot.
It's not easy to spot at all, but you could measure its function - pull the plug on the ECU and measure from the appropriate pin to ground while you press and release the brakes (with pressure available of course) - thats how I tested my switch when it was faulty.
I see no reason why the switch couldn't be retrofitted, and if the post about the V6 is anything to go by it may actually be fitted, just not connected in the loom anyway.
Regards,
DickieG
x 38
Well I took my HDi with the repaired ECU for a good 300+ mile test drive today (you do need to give a decent test :wink: ) to pick up a Lexia. I'm pleased to say that all went well with the ECU working 'as new', mind you when I plugged the Lexia in and tested the Hydractive ECU it had just about every fault you could think of recorded. I'll scan it again again over the next few weeks and see what happens. Hmm, Lexia I'm in love :oops: what a wonderful tool :D .
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
falling-out-with-my-car
x 25
changing to different spherws on an Xantia
Hello, everyone, my old citroen mobile mechanic Kevin masters once told me that if I wanted a softer ride to have BX 1.9TD spheres fitted on the front only, i have an inoperable hernia and a days driving can cause a lot of pain from driving for long periods, I hoped that i would get asround to trying this out I did ask if there was any chance of loosing grip on the road esspecially in cornering at high speed ie 40MPH on roundabouts but he didnt seem to think there would be much difference in road holding.
he dissapeared and we were never able to contact him again I think he either had a nasty accident on the way home or went bust due to our ever increasing price hikes in the UK. I hope its the latter. he was a very good mobile mechanic and we have all missed his services greatly.
a third of the price of any main dealer and he came to you, he still owes me a pollen filter. i am struggling to find any mechanic in or around kettering northants who will adequately replace him. if anyone knows of someone please get in touch. its always handy for the bigger jobs, head gaskets etc , dam hernia means I can't turn big spanners or socket sets these days and I'm only 42.
Regards Nigel.
Regards Nigel.
admiral51
x 391
Re: changing to different spherws on an Xantia
Unread post by admiral51 »
falling-out-with-my-car wrote: a third of the price of any main dealer and he came to you, he still owes me a pollen filter. i am struggling to find any mechanic in or around kettering northants who will adequately replace him. if anyone knows of someone please get in touch. its always handy for the bigger jobs, head gaskets etc ,.
Jim, looks like there is an opening for you should you ever decide to leave IT as a career :) :)
how many tools can you fit in the back of the estate :lol: :lol: :lol:
Colin
x 8125
admiral51 wrote:Jim, looks like there is an opening for you should you ever decide to leave IT as a career :) :)
It's a thought that is always in the back of my mind Colin although I'd be after a BX van for such a venture :lol:
I'd love to do it but currently I have too many very hungry mouths to feed to contemplate giving up my regular and secure employment just yet. Mind you, I'm only 9 years off retirement and maybe a lot sooner than that if I can secure early retirement or the hoped for redundancy with a good severence payment :lol:
x 25
IT as a job
And i was thinking about starting out as a freelance it techy LOL.
Jim there are at least six citroen owners who have been let down near me in Kettering and god knows how many more i don't know of.
DickieG
x 38
DickieG wrote:I'll scan it again again over the next few weeks and see what happens.
Having done quite a number of miles recently I'm pleased to say the repair is still working OK, no faults recorded in the ECU either.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
