Radio Code Number
mikep
Radio Code Number
Unread post by mikep »
Can anybody help me get my radio back on ? I have what I think is the code --3959--yet if I follow the book instructions I have to use the numbers on the console and they are only 1-6, so how do I put the 9 in ?
or do they mean the start number panel ?
mikep
Citroen Xantia auto sx 1996
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi mikep
if memory serves me well you press buttons 1-4 on the radio (station presets) the number of times required to bring up the number you want
in your case
button 1 3 times
button 2 9 times
button 3 5 times
button 4 9 times
not sure what button next to accept code probably 6 but could be wrong
hope this helps
colin
x 8310
6 it is :D
mikep
thanks guys I'll try it tomorrow
mikep
moresthepity
radio code
Unread post by moresthepity »
Hi guys, just wondering if anyone knows how I can crack the code for the radio on the xsara iv just got?? thanks
Gammy leg
Unread post by Gammy leg »
James,
Go to your local Citroen dealer, if it is the original set they will have it on record. All dealers should have access to this data not just the one that supplied it. You may need to prove ownership of the car ( logbook etc ) and will need to supply Reg. No as a minimum. Whole process takes less than a minute. Best to go in person as many can't be bothered if you enquire over the phone.
ps. You have to hope though that none of the previous owners have changed it.
Gammy
falling-out-with-my-car
x 25
radio code
If the previous owner has changed the code the stereo can be reset but it has to be removed and sent away, it will come back with a new code and a sticker on the side with a citroen code to order a new code if that code is lost. confused? i was.
£15 for the inital new code reprogramming cost around£50 at amain dealership.
regards Nigel
