I found a small leak at the rear of my Xantia, its very minor, leaving a couple of drops daily on the drive when the car lowers manually or automatically.
I've used Wynns products with confidence to help leaks and issues with gaskets, seals, smoke etc. as a first attempt to cure the problem
I spotted this, which is compliant with LHM, http://cgi.ebay.ph/WYNNS-POWER-STEERING ... dZViewItem
worth giving a go?
Small LHM leak found
- x 1479
I'd have thought you would be extremely unlikely to seal this with any stop leak. If it leaks on lowering then most likely the return from the height corrector is perished. Get it up on ramps and the spare wheel and carrier out, and find the leak - probably get away with just cutting the end off the tube and shoving it back on for now.
