Ok, I now have the head off the car, I have checked it with a straight edge & I'm happy to tell you its as flat as a very flat thing
However the piston liner protrusion above the block is way over specification
Using feeler gauges & a straight edge I can get a 0.25mm gauge under the straight edge…but I would estimate the gap to be a smidge bigger than this
The head came off the block with no struggle at all so I doubt this could have disturbed the liners & the engine certainly hasn’t been turned over since the head was removed (Flywheel locking pin still in position)
I have tried tapping the liners down to see if they would move with a block over them & a few swift blows but there is no movement at all.
Can anyone advise on this problem as the Haynes doesn’t really explain what you should do if the liners aren’t within spec?
Regards.
