Xantia Rear Ride
PicassoPigeon
Xantia Rear Ride
Unread post by PicassoPigeon »
I can move my xantia up to the top and down to the bottom no problem. When I move from the low setting to normal the rear does not come up I have to move the lever to high and quickly back to normal to get to rise. Is this a Height Corrector Linkage problem?
gav425
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
jeremy
x 3
Unread post by jeremy »
Yes - most likely - loads of info on them on here. They seize up and break the plastic link.
Remember to support the car so there is sufficient room for you should it drop on the suspension. These cars can KILL.
jeremy
