Hi.
Having decided to replace the blown up engine in my Xantia 1.9TD Estate, I want to know if its possible to use the aircon pump from my old engine with a non-aircon engine?
There are a few 1.9TD engines out there, but most of them seem to be non aircon.
The swap will be done by a mechanic friend, but i need to keep costs down and dont want him to find out that they are not compatible.
Any help very appreciated
Cheers
Engine swap - can i add aircon to a non-aircon engine?
pete the bus
- x 1434
Shouldn't be too bad - you will need to swap the sump, aux drive belt fittings, and possibly alternator and HP pump from your old engine to the new one. It's probably less hassle than fitting the non A/C engine where you will need to modify the alternator wiring and piping to the HP pump to make it fit.
alan s
- RIP 2010
- x 6
Agree with Richard but will add just one point; don't throw the old set up away until it's installed and running. For certain, there'll be some little bit that you'll need.
Also, be certain you draw a "mud map" of the route the accessories belt takes when it snakes around all the pulleys and tensioner. Puts the reason why the belt is known as a "serpentine" into perspective.
Alan S
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
- x 1238
alan s
- RIP 2010
- x 6
- x 1238
alan s
- RIP 2010
- x 6
