Xantia rear stuck in high postion.
Barbarian
Unread post by Barbarian »
I moved my xantia into high position then when I tried to put it back to the central position the front end came down but the rear end remained high, So I
left it over night and when I went out in the morning the rear end was still high, so I started the car up and it tried to level itself out But this caused the rear end to sink to its lowest position and remain their. So I Put it back in high mode and the both ends raised up but the rear end wouldn't go back down to the central position again!.
I am I looking at knew spheres or what? What sort of price range am I looking at a repair from a small back street garage?
cheers
KP
x 27
Unread post by KP »
I'd guess your hieght corrector is siezing up towards the end of its life :(
You can try spraying WD40 and the like on it to loosen it up and move the leaver in the centre console back and forth while the lubricant is being sprayed and see what happens. If this fails then its time to get it replaced :(
Also be carefull as the car can drop very quickly without warning as well so dont go under an unsupported car! :(
rory_perrett
Unread post by rory_perrett »
Or the plastic link between the height corrector and the roll bar clamp has come off.
Rory
Barbarian
how do u access the height corrector?
x 8253
Jack up and support on axle stands (VERY IMPORTANT for the reasons stated), crawl under and looking in the middle you'll see the height corrector attached to the end of the linkage from the height lever. It looks like a cylinder with a rubber end cap. On the other end of it you'll see a white plastic balljoint link going to the anti-roll bar. This is the link that has most likely hopped off because the height corrector mechanism is seized.
Douse the mechanism in WD40, exercise it and then grease it well. Pop the link on (if it has popped off) and see if normal operation is restored. The clip may be broken/ cracked but is very cheap to replace. It is a dealer-only part though.
The height corrector mechanism corrodes badly and a replacement height corrector may be required.
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
Had this happen to the front of mine last year, exactly same symptons - bought a new ball joint for a quid or so.BUT as as citrojohn pointed out, if you're not used to working on these cits you must have it supported 'cos moving that height corrector only a tiny amount causes large suspension movements (ouch).
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
MikeT
x 232
Unread post by MikeT »
All what they said above :lol:
SUPPORT THE CAR WITH AXLE STANDS because if it decides to lower itself IT WILL SQUASH YOU otherwise.
It was the first problem I noticed when I got this xantia and it all seemed confusingly difficult to tackle but it really isn't if you can get over the worry of the car crushing you!
If you do a search for "plastic" you should find numerous relative (and probably irrelative) threads but there are some pictures to give you an idea of what you're looking for.
The plastic clip popping off is the most common reason though it's usually due to either wear or seizure. I was lucky as the front clip had simply worn and it cost me £1.99 for a new one. It was easy to fit as my corrector was not seized and I just had to lever the spring loaded joint back and on it popped. Make sure you add a little lubrication to each cup and soak the little felt washers in oil to keep them lubed.
deian
Unread post by deian »
So if you accidentaly get it working by chance it will drop with no warning. Your circumstance are exactly the kind of conditions a Citroen needs to kill you, fiddling with the 'height corrector'. So be clever! Support with axle stands!
admiral51
(Donor 2026)
x 394
Unread post by admiral51 »
try this link
http://www.frenchcarforum.co.uk/forum/v ... or+linkage
try searching" height corrector linkage"
hope this helps
colin
