abs sensors
admiral51
x 392
abs sensors
Unread post by admiral51 »
i have just finished dismantling my dead xantia and have mixed up the abs sensors without lableing them :oops:
they are both from the front so do they have to go sided or will anyside do
one other question can you use front sensors for the rear sensors though that question is probably going to be answered by the first one :lol: :lol:
cheers
colin
i dont need them just want to make sure if someone wants one i can send them the right one :) :)
x 94
Unread post by citronut »
hi Colin
i dont think the sensors themselfs are diferant, the diferants is probably the length of the cable and the mountting points, so if these are the same they should be able to fit other corners
regards malcolm
andmcit
x 30
Unread post by andmcit »
There is a difference in the lengths of the lead and the support ring
positions comparing the front and rear sensors.
The thing you do need to watch out for though is the 'reach' of the main
sensor's cylinder body relative to the CV joint ABS ring. This is important
as the support shoulder mounting onto the hub has two different insert
brass insert collet depths depending on the size of the driveshaft and
there are differring sizes according to the specific Xantia age/model
in question.
Andrew
admiral51
x 392
thanks all
the cable lengths are the same and as they came off the front discs ill assume they fit either side
cheers
colin
admiral51
x 392
hi superloopy
give me a pm with an offer inc p+p and its yours they are surplus to my requirements no abs on my goodun :lol:
not sure which is which as ive mixed them up in box with no label i know DOH but ive got a shed full of xantia bits now and i was in a hurry :oops:
the two ive got are both from the front and both are working
just as an aside ive also got the abs ecu available (1996 P 1.9td sx)
colin
