Guys,
Here is a simple way for adjusting Xantia's height, calculated from a Xantia that after adjustment got superb ride quality:
Just ajust rear height so distance between rear wheel rims's border and the (wheel cover? don't know the right name for the part) is:
For 14 inch, 187,65 mm
For 15 inch, 163,25 mm
Then equalize the front by aligning the car to the ground.
If you have an excellent ride and your car has a dfferent measure then please post here!
Tip measure for setting Xantia Height
pprado
Pedro Prado
Pedro Prado
- x 694
Re: Tip measure for setting Xantia Height
Hi Pedro,pprado wrote:Guys,
I hate to be a wet blanket - but I don't see the point of this.
So while these figures might be good for your car they're most likely wrong for many other people. I refer you to the following scans:
http://homepages.igrin.co.nz/simon/imag ... ia_height/
As you can see, many year/model variations.
Another trap to fall into when adjusting the height for "best ride" is that invariably setting the height requires lots of up and down movement of the suspension - otherwise known as citrerobics, and if you have any air bubble issues this can give a temporary improvement in the ride which may lead you to believe that the new ride height gives better ride, only for the ride to deteriorate later.
I have been down this road many times, believing that a change in ride height I had made had improved the ride, and I eventually realised I was just being fooled, set the ride height back to exactly what is specified in the book above, and left it alone...
Regards,
pprado
Hi Simon,
It´s just an easier way of measuring, with a knowingly good ride height.
To add, these were taken on a 1995 2.0 8v Auto VSX.
Knowing these should make easier for someone who just want to CHECK if the height is near correct.
At least around here, almost every owner asks about the correct height but when told how to measure, 90% just don´t do it
Pedro Prado
Pedro Prado
TehAgent
- x 6
man, well it confuses the hell out of me, and when comparing the rear of my car with that of someone else, the rear of mine always seems like its sitting to high, yet my ride is lovely, even with my 4 year old spheres
And mandrake, although i love the look of them scans, I'm still confused as to how they are measuring that, as I'm not to good with technical drawings and talk. so for the layman like me, its not very helpful.
Peugeot 208 active 1.6 EHDi
BMW 330i 2007
Mx5 Mk1 1990
BMW 330i 2007
Mx5 Mk1 1990
- x 694
Hi,TehAgent wrote:man, well it confuses the hell out of me, and when comparing the rear of my car with that of someone else, the rear of mine always seems like its sitting to high, yet my ride is lovely, even with my 4 year old spheres
Yes they do look a bit technical but they're really not that difficult.
Basically you measure from the ground to the exact centre of the wheel in millimetres - that is your figure for R1. This allows for variations in wheel rims, tyres, tyre pressure and load.
Then pick your model of car from the table - this gives you a figure L1 in millimetres - this accounts for differences in different models and years.
You then add or subtract them as shown in the formula (subtract for the front height or add for the rear height) and you now have a figure in millimetres that is specific to your car.
Now you measure this figure between the ground and the place on the suspension chassis where the picture shows to measure. Make sense ?
Here is a simplified diagram which shows those values precalculated for a few tyre sizes, unfortunately it doesn't say what model they are for, but I am guessing 1.9TD and 2.0 petrol:
http://homepages.igrin.co.nz/simon/imag ... height.jpg
If your figures for H1 and H2 are in the ballpark of these ones you know you have worked things out right...
Regards,
pprado
Yes Simon, for us that used to be more below the car than inside it, that is easy
Kiddin... Truly, the official procedure is easy, and I can say that one SHOULD use it if he decides to adjust the car.
But, For a simple check, just to see if a given car is way too far from its spec... Anyway, good point telling the differences between years. Will check mine to see if it falls in a different height than my friend´s VSX Auto.
How can one tell if his front struts have hydraulic stops?
Pedro Prado
Pedro Prado
