I fille dup by diesel Xantia last night, on the drive hokme a noticed a regular click coming from the instrument area of the dashboard. No other apparent problems turning lights, radio on/off didn't help.
After a while I realised that the intervals had stretched from around 1 second to about 3. When I got home the clicks faded to nothing.
I had a poke around and went back out for a drive, the faster I went the faster it clicked, continuing when the clutch was in and independant of revs.
It was only on my way back when I wondered how many miles I had done trying to find the problem when I realised that the tripometer was stuck between 111 and 000. I always reset it when filling up the car.
Well I thought it was funny,
mipzter
funny click
alexx
rabenson
BonceChops
Since i bought my Xantia TD I sometimes get a clicking from behind the dash, near the fusebox. It sounds like a relay energising on and off several times a second. The speed varies sometimes and after a while it usually stops. I cant find out which relay it is as it stops before I get chance to find it. Anyone any idea what it might be?
AndersDK
Some time ago I tried to advice on a similar problem - and learned from others that a small fan is located in the cabin air duct [:D]
This fan is to keep an air flow over the temp sensor - such that the cabin temperature constantly regulates correctly.
This fan can emit vague humming sound - as well as vague ticking.
BonceChops
cheesey
hi.
I had varible clicking from behind the dash too. It turned out to be a short in the column switch for the indicators. I think it caused the indicator relay to click on/off but it did not make the indicators light up. This can happen when the relay does not get enough power to pull down the contacts inside.
94 1.9 td sx
94 1.9 td sx
BonceChops
wrinklet1
Hi Mipster
I think you may find that the noise thats coming from your dashboard is nothing more than the trip meter. If you pressed the button to reset your trip meter when you filled up, it may not have reset properley. Make sure your stationary and reset it again. The noise should stop then.
Regards
Paul.[xx(]
Regards
Paul.[xx(]
mipster
