1) Low speed radiator fan not working resulting in 'STOP' light when main rad fan operates.
A similar thread mentions 'two resistors with coils near the fan' were the culprit - can someone point me in the right direction to find these resistors...
2) Battery warning light mostly on. Have tested voltage at battery and this increases to 14v when started, so it would seem alternator is ok...
Thinking this problem might be solved by disconnecting the car battery for a few mins (in case of glitch in the ECU), I now have a new problem
3) My remote key fob now won't operate. Have tried the reset method when replacing a keyfob battery (ignition on - hold any of the 3 buttons for 10secs) to no avail.
Is a different reset method needed when replacing a car battery ??
Cheers,
Keef
