Some of you may well remember my Xantia 2.1 with a knackered pump. I have not been able to locate a second hand one anywhere.
Is there anyone interested in my car as spares or repair. All it needs it a pump. The rest of car is is great shape. Interior mint. 112k miles Dark green, alloys, aircon. New cambelt, aux belt, front and rear disks and pads. oil and filters at 110k
Poor old 2.1
Sturdybloke
slim123
- x 1240
I take it this is the EPIC pump, as the purely mechanical ones seem to last forever. Had you thought of fitting a mechanical pump, there must be loads of those around and the swap shouldn't be difficult. If its the same as the XM even the throttle cable is the same, just ends in a different place. If it isnt the same make as your existing one (Bosch or CAV Rotodiesel) you will need to change the injector pipes a well.
deian
don't limit your search to just a xantia, the xm had the same engine, and i think also the synergie, the pug 605 etc etc, look in scrap yards, on ebay, wherever, there must be a cheap car somewhere to buy, cheaper than a pump, you can then sell the car as spares or repairs or sell it to the scrappers to reimburse urself... good luck
- x 1240
xf8u
xf8u
Xantia 2.1
Hi slim, I really would be grateful if you could help me out here. I have tried all my local breakers in Manchester. It is the Lucas EPIC injection pump I need. It's not the mechanical one.slim123 wrote:Sorry but I dont know anything about this, What pump is it?? Hydraulic, Diesel or Water pump.
I know some good breakers and may be able to find one.
Regards
Slim.
Can anyone help?
Mike
- x 8260
weety
on the bay these guys are selling a 2.1 engine so might be persuaded to part with the pump
http://stores.ebay.co.uk/NCS-PEUGEOT-AND-CITROEN-SPARES
as are these guys
http://cgi.ebay.co.uk/CITROEN-XANTIA-2- ... dZViewItem
and is this the same pump
http://cgi.ebay.co.uk/espace-2-1-turbo- ... dZViewItem
xm pump (but probably to old)
http://cgi.ebay.co.uk/Citroen-X-M-2-1-T ... dZViewItem
as are these guys
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
AndersDK
Removing the pump from a good engine makes the engine just about worthless. Not an option IMHO.
You would have to buy the complete engine then.
The XM2.1TD pump is exactly the same - in the earlier purely mechanical version.
Donno on the Renault Espace. They had some variants with PSA engines. It looks pretty much the same as the XM one, but would also be a mechanical pump.
Even if still an expensive solution, a trade in swap for an overhauled & tested unit may still be the cheapest option. Could be more than the trade value of the car though
Anders (DK) - '90 BX16Image
Xaccers
- x 186
Argh! And here's me with no money!
I wonder if they have the pipes and injectors...
DIY sphere tool
DIY sphere tool
- x 8260
I had a quick look at that one Andy. It's got a throttle pot on it and will have the electronic timing control so in addition to the injectors and pipes, you'd also need the ECU to go with itXac wrote:Argh! And here's me with no money!
I'd steer clear of this particular one. The picture shows it apparantly black, wet and dirty. This suggests to me it's been leaking. Diesel seems to leave black stains.
- x 1240
- x 8260
Fully in agreement with that PeterPeter.N. wrote:I am still sure it would much easier and cheaper to fit a mechanical one - not to mention - more reliable![]()
The pump backplate also has plenty of spare tappings for other pumps as well.
I keep on pondering how a pump designed for a 1.9TD would behave on a 2.1TD but it really needs someone willing to go for it to see how it works.
