406 WATER TEMP. CAPTURE
jonasy
Unread post by jonasy »
RFV(XU10J4R)engine, there are 3 water temp. sensor beside engine, they are blue, brown and green from up to down. which one is for trans signal to ECU?
x 8444
The green one.
The Brown one is the BITRON Sensor for cooling fan control (in conjunction with the A/C) and the Blue one is the temperature gauge sender.
jonasy
citrojim wrote:The green one.
thanx.
could u pls let me know the 6 digital code of accessory of PSA for this green one?
i want to change the one which works on oil injection after ignition, which one?
besides, for xu10j4r(rfv 2.0 petrol), why dealer said there are only 2 sensors? from up to down, they are blue, a plug(without sensor), brown.
but mine is exactly equipped with 3(blue, brown, green)
