The electronic motor drive, pins 3 & 4.
Last map, top right, sonde température habitacle ventilé.
Citroen are asking £Too muchAndersDK wrote:Mike -
Before you dig too deep into this issue - call Citroen and ask for a spare parts price tag.
Sounds like a contradiction for my simple mind - is there or isn't there an electronic controller required for brushless motors?Third : there is no elctronic control for the brushless DC fan motors. Its build in behind the blower blade rotor.
Yes, 3 caps, one resistor and a sprinkling of surface-mount components but the power (+12V & -12V) for the motor passes through this circuit (as well as the temp sensor) and becomes four outputs to the motor windings.What you see on the PCB is the temp sensor itself, and possibly a couple of radio interference decoupling capacitors.
Desoldered and waiting 8)With some fiddling it should be easy to move the pcb over to to new blower. Be prepared though that you must power up your soldering iron
to be back.A motor for this function would normally not need an electronic drive, because it always runs at the one full speed.RichardW wrote: it seems to use some sort of modulated signal to make it run (presumably to keep it quiet) and what seems to happen is that the electronics give up which causes the fan only to kick when switched on and not run.
Ok.AndersDK wrote:Things are mixed up here.
To clarify :
Yes - a brushless motor needs electronics to run off a DCvoltage.
Looking at the parts I have, I can't see any circuitry in the motor at allThe necessary electronic circuit is built into the fan itself. Thats why it has a relative large mid-section. That midsection is NOT only the bearing - but a tiny PCB with some transistors etc.
You will instantly recon if you break the old fan apart.
(you will find a tiny axle C-lock ring under the paper label on the fan)
