Here's a good one!... I put the demisters on full blow and now it won't turn off. I can redirect and change the temperature etc. but I can't turn the blower fan off - it's stuck on full power. Until today, it's always worked fine.
I have climate control with A/C and had previously noticed the fan blower only operated after a short delay from engine start.
Now, the blower comes on as soon as the ignition is turned on.
Does this ring a bell with any of you experienced owners? I'll have to decipher the Haynes BOL again now.
Heater Blower can't be switched off
den169
AndersDK
MikeT
- x 232
Haynes diagram shows a speed control and speed resistance module in the circuit. Could be either one of those I guess.
I also searched the forum and it seems a certain transistor failing is a common fault.
One poster had rainwater leaking over the blower from a cracked windscreen scuttle...
My scuttle is also broken and rainwater is dripping in to the passenger footwell
- x 1240
MikeT
- x 232
- x 8306
Tha was the exact symptom I had when one of my blower transistors went. Fan on full as soon as the ignition was turned on. There should be a delay before the fans start on initial ignition on and they should not run until the engine is started and running.MikeT wrote:Well this one won't turn off, even with the engine not running - does that change anything?
Must be something specific to a MKII model.
The transistors are available from Farnell Electronics and not hard to swap if you are handy with a soldering iron.
- x 1240
MikeT
- x 232
And MKI's jimcitrojim wrote:
Tha was the exact symptom I had....
We got a maplins in Bournemouth and I can solder in my sleep but I better cure the water leak first.
Anyone got a spare scuttle they don't want or would silicon sealant underneath work? Worth a try I think. Thank you!
MikeT
- x 232
Mistakes happen Peter, I'm grateful for all you kind people here and the assistance you volunteer, thank youPeter.N. wrote:The 'when the engine is running' may have been a red herring on my part, as I think its the supply to the control unit that's only there when the engine is running - apologies. It depends how the transistors have failed - collector/base or collector/ emmiter short. Transistor type on my signature.
- x 8306
Mike,
Maplins won't have them. Farnell are the only source I know of.and they have a £20 min order. I have a spare set so if you want 'em let me know.
This (my experiences of swapping them) may be of interest. Do another search on "transistor" and loads of very useful stuff will come up.
http://www.frenchcarforum.co.uk/forum/v ... transistor
Silicone sealant (a good autmotive quality one) will be fine Mike. Do check under your carpets for water though and be prepared to have the carpets out
MikeT
- x 232
If I opt to repair, I will buy from you - how many do I need? Problem is, I'm finding too many faults with this car and as much as I like it (air-con, cheap veg fuel etc), I think I'll have to sell it on.
My carpet is wet so they will come up if I tackle the blower. I have an alarm fault too and believe the module may also be immersed
Cheers
Cheers
- x 8306
Mike,
I was just thinking that you are going through all the same pain as I had on my Activa. I know exactly what you are going through and I got to the point when I got so despondent I thought of scrapping the damm thing.
This after a long period of totally trouble-free (which continues) with my old TD Xantia.
Stick with it, you have come so far already! Get these problems sorted and I guarantee a long period of trouble-free running. My Activa (touch wood) is now OK and I'm down to doing minor work now. Yours will be the same very soon.
It'll be worth it in the end, you'll end up loving it and feeling sorry for all the non-Xantia drivers out there and the expertise you have gathered will make you very confident with it.
PM me your address and a pair of transistors will be in the post tomorrow afternoon.
MikeT
- x 232
Thanks for all the support and encouragement Jim but if I was to show you all I've found so far, you may well agree it should be scrapped. I won't go into detail here, but take it from me it's too much, better to spend the money on a nicer example of Xantia I think. I can use my new found experiences/expertise to better judge my next purchase
I only bought the car because it was cheaper than re-taxing my Granada! I've owned a Xantia before... and with this one being TD, taxed and mot'd, thought it would be a good experience so bought it!
The Xantia does have some major advantages over my Granny and intially I was inclined to keep it and sell the Ford but this Xantia is proving to need just too many jobs and too much money for my failing body and meagre wallet.
By the way, do you know of any easy way to temporarily disable the blower other than removing the fuse?
Thanks, Mike
Thanks, Mike
- x 1056
