HELP NEEDED no2!!!!!
jamieclayton9
Hi all. when i am driving my xsara 1.9td 1998 every now and then i get the stop light on the dash come up and the light on the tempruture guage. i assume that its to say the car is over heating but it is not. it can even come on just after i start the car. any idea what it could be. many thanks. jamie
- x 94
JohnD
- x 72
Re: HELP NEEDED no2!!!!!
No! ------------------ But when you find out, let me know. My daughter's Xsara does the same thing. Presumably it's a dodgy connector some where.jamieclayton9 wrote: any idea what it could be. jamie
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- x 8058
The overtemperature light is usually on its own sensor on the thermostat housing. It'll most likely be dodgy connections. I cannot recall off hand what sensor it is but it'll be one with just one connection even though it will have a two pin plug on it.
The lamp needs an earth to light so the problem may be a bit of dirt and corrosion has got in (a bit of coolant maybe?) to the sensor connector.
Clogzz
- x 40
KevMayer
You get the same lights on a 1.9 td Xantia. In that case it's caused by the Bitron unit which controls the cooling fans etc.
The Bitron is supplied by a brown coloured temperature sensor which is mounted on the fuel filter base.
Now, I don't know if your Xsara has a Bitron unit but if it does, the problem is usually a build up of oxidation on the brown electrical connector on the temp sensor. Just pull it off and push it back on a few times and it will probably cure the problem.
good luck,
Kev
good luck,
Kev
Cheers, Kev
Clogzz
- x 40
In addition to that, the Bitron pins are tinned with solder, and in time the contacts become dodgy, most obviously pins 7 & 14 that have the resistive brown sensor input.
I had this problem, and cured it by scraping the Bitron pins with the rough end of a piece of broken metals hacksaw blade.
A previous squirt of WD40 on the Bitron pins was good for only a few days.
Citroën in France made free out-of-warranty brown-sensing modifications back then.
It wasn’t a recall, or correction, or modification ... it was an evolution:
http://xu10j4r.free.fr/xantia/notexantia.pdf
2002 C5 2.0i AL4 239,000 km 76372389
jamieclayton9
jamieclayton9
