Xantia 1.9td EGR system?
howiedean
Unread post by howiedean »
I’ve been trying to work out how to improve the performance of my Xantia, see my other post on poor acceleration. :( I would be very interested to know if anyone has a photo of the EGR system alternatively have a good description of how to disconnect it?
Thank you very much,
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
The EGR valve is controlled via a solonoid positioned on the bulkhead above the gearbox, there are two solonoids there, the other controls the idle speed. To disconnect the EGR valve simply pull the rubber hose off the solonoid.
I'm not sure that disconnecting the EGR will make much difference to performance because IIRC it only opens at idle speeds. However what you will achieve is stopping a horrible black slime being ingested into the engine which I understand causes problems at higher mileages.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Kowalski
Unread post by Kowalski »
The EGR system is irrelevant to the performance of the car, if the valve sticks open, its small diameter pipe compared to the manifold diameter so it can only "dump" a limited amount of your turbo boost pressure and do no more than that.
I remember fastandfurryous posting on here a while ago about a TD 406 that he removed the inlet manifold on and cleaned. Apparently the manifold was full of carbon and oil because of soot from the exhaust going through the EGR system and mixing with the oily residue thats found in your inlet manifold. I've looked inside my manifold and seen it thick with black gungy stuff, perhaps thats happened to yours too.
fastandfurryous
x 4
Unread post by fastandfurryous »
Kowalski wrote:I remember fastandfurryous posting on here a while ago about a TD 406 that he removed the inlet manifold on and cleaned.
You've a very good memory... that was the better part of 3 years ago (I think...!)
Indeed. EGR is a horrible device. Theoretically, it reduces the amount of oxygen in the intake charge of air at idle/low engine load, which in turn reduces the oxides of nitrogen emissions (a bit). It was introduced as part of Euro "2" emission regs in about 1997-ish IIRC.
It does also admit soot into the intake manifold, which mixes with the oil which all XUD engines have in their intake manifold (from either the breather, or the turbo, or both) and makes a right royal mess of the intake system.
The 406 I dismantled had literally a 1/4" thickness of this goop everywhere in the inlet manifod, the inlet ports, and all over the inlet valves. The intake ports had been reduced to about 1/2" diameter in places. It took for-****ing-ever to clean it all out.
My advice would be to physically remove the valve. Blank off the manifold ports and plug/remove the vacuum pipes that drive it all. Remove and clean out your inlet manifold too. EGR can only cause problems. The MOT emissions test is completely unaffected. (in fact you may perform better, as the car can now actually breathe properly)
A similar thing happened to a friend's Audi 80 TDI, so the problem is not PSA specific.
This is not a signature.
howiedean
As I use a gloopy fuel anyway, I guess that the EGR will be caking up the intake manifold on my motor!!!
Do you happen to know if anyone has got an idiots guide on how to disable the nasty EGR system?
Any advice and I would be greatful.
Cheers
Howie
fastandfurryous
x 4
Disabling it will simply mean that the problem will not get any worse. To fix the problem:
Remove inlet manifold. Remove EGR valve (sortof comes out with the inlet manifold anyway).
Make up plate to blank off the exhaust manifold port (or fit earlier-type manifold). Make up plate to blank intake manifold (or again, fit earlier-type manifold)
If keeping the old manifold, wash it out with petrol, diesel, kerosine, pressure washer, gunk white spirit.... ANYTHING that gets the crap out of it.
Put it all back together.
Note how much faster the car now goes.
If you want to do a "complete" job, then really the head needs to come off, the ports cleaned out and the valves cleaned & reground in, but that's lots of work.
Eventually, what remains of the goop should slowly dissolve, and dissapear of it's own accord.
howiedean
Fast reply fastandfurryous!!
Great I'll have a look at doing this job very soon. What needs to be considered regarding the vacuum pipes? I have already disabled the cold start system as this didn't work when I 1st purchased the car.
cheers
Howie
fastandfurryous
x 4
The vacuum hoses can be removed. I think I left the electrical solenoid connected on the 406, as it seemed to "know" that it wasn't connected, and throw up a fault, so the solenoid valve is still there, clicking away, just doing nothing.
The vacuum pipes were all removed. The vacuum "supply" came from a t-piece with some other vacuum system, so the t-piece was removed to make it look like the system was never there.
howiedean
fastandfurryous wrote:The vacuum hoses can be removed. I think I left the electrical solenoid connected on the 406, as it seemed to "know" that it wasn't connected, and throw up a fault, so the solenoid valve is still there, clicking away, just doing nothing.
One last question on this topic honest!!!!
If I simply disconnect the Vacuum pipes, how does the EGR valve react?
I wasn't if it would default on or off?
Regards
Howie....
Howie
fastandfurryous
x 4
If you remove the vac pipe from the EGR valve it will stay closed. Vacuum is applied to open it.
davethewheel
Unread post by davethewheel »
not sure myself how you would do the job correctly but when i first got my 2.1td xantia it was down on power and smoking badly due to the EGR valve sticking so i pulled of the rubber hose leading to it and stuck a bolt in it just to try it and it made a huge difference to the performance and stopped it smoking, it's been like that ever since :lol:
i had a look inside the manifold and it's completely caked in black goo :shock:
fastandfurryous
x 4
davethewheel wrote:i had a look inside the manifold and it's completely caked in black goo :shock:
TaDaaa....
....and for my next trick....
howiedean
fastandfurryous wrote:If you remove the vac pipe from the EGR valve it will stay closed. Vacuum is applied to open it.
Ok I lied one more question. Closed is :( and Open is 8) I take it?
Howie
Howie
fastandfurryous
x 4
No. The valve needs to be closed. It's when the valve is open (thus allowing exhaust into the inlet manifold) that the problem occurs.
With the valve closed, it's effectively a non-egr engine.
howiedean
fastandfurryous wrote:No. The valve needs to be closed. It's when the valve is open (thus allowing exhaust into the inlet manifold) that the problem occurs.
Thanks for that... I now understand the system a little more.
Cheers
Howie
