Hi, what do you call the hydraulic ticking? is it a 'tick' noise or a 'shhhhhcome' noise? if it's the 'shhhhhcome' noise, mine does it every 5 seconds, with a new accum. sphere and new HP pump too. If it's a 'tick' noise mine doesn't do any.
Any ideas?
Paul.
Define hydraulic 'Ticking'
- x 1499
Paul,
Older Cits tended to a definite 'click' as the regulator dropped out, particularly with a tired regulator and knackered accumulator. The Xantia, however, tends more to just a 'Shhhhcome' noise (as you so eloquently describe it!). 5 seconds is way too close together, so you must have an internal leak somewhere, or your PR is past its best.
Richard
Richard
bxbodger
blueboy2001
tomsheppard
bxbodger
At the last MOT all the high pressure hydraulic lines from front to rear were all failed due to corrosion, and the rear brake pipes too, so I replaced them all, and fitted all new seals as well,along with new rear suspension cylinders as the brake pipes were well and truly seized after 14 years of roadsalt and dis-simmilar metals, and, hey presto, no leaks and 5 min. long intervals between clicks!! The system has also had regular fluid changes and filter cleans, which all seem to help as well. I dont believe any system, high or low pressure, should leak; no-one would put up with it in their domestic water system, and even BL hydragas systems stayed leak-free for years!!!
tomsheppard
jeremy
- x 3
Another design feature you will appreciate aftera time is that the citroen hydraulicas are largely free of moving seals and rely on finely machined components for seals. Some minor leakage is ok and is returned to the reservoir, but if the leakage gets excessive due to component failure it can overwhelm the return system and pop off the joins or break rubber pipes.
Works very nicely most of the time!
jeremy
jeremy
tomsheppard
This is why the tick time varies with temperature. The viscosity of the LHM becomes lower after a good run and all the components being hotter and having expanded slightly, the time can fall quite dramatically. sone of the bits are finished to a tolerance of a thousandth of a millimetre- 1/25 of a thou!
