jeremy wrote:Of course Norton may be the problem - I threw it out as the thing wrecked my old computer (Waste of £50 or something) and removed it from this one as its expensive and kept displaying silly messages to make me think its actually doing something.
Exactly what I did to my wife's computer.
She was so frustrated about those Norton messages every now and then - not understanding what they meant. Above all it degraded the computer substantially.
John, I've just re-read this whole thread - and I stumbled over the fact that you do not mention that you have checked the WindowsXP network setup.
This you reach from :
Rightclick other computers (network) -> options -> rightclick any named connection you see -> options -> new window
here you should see at least these 3 services installed :
client for microsoft network
file and printer sharing
TCP/IP services
At least you should have the same services installed on both computers.
highlight TCP/IP services, then click the options button
everything here should be set to "get automatic"
do NOT specify any DNS or DHCP servers.
What happens is that windows in this setup will issue a DHCP request (the address 000.000.000.000) out on the network connected to. Any DHCP server listening will immediately wake up and respond with the necessary IP adressing details sent back.
If it still doesnt work - then its your router, modem or whatever internet connecting device you have that does not respond, or will not allow a transparent DHCP request sequence.
You might then have to interrogate this device to check its setup, as it could be lost somehow.
Look in the CD documentation files that came with your device.
