Sphere removal tool - again ;)
LeeDJC
Unread post by LeeDJC »
I just came across a sphere removal tool on ebay...
http://cgi.ebay.co.uk/CITROEN-BX-CX-XAN ... dZViewItem
They look a little different to the design of the ones that I have seen before, but also a little cheaper than the pleiades ones.
Does anyone have a tool like this one, and is it any good? As I've got 10 spheres to change on my Activa, I would like a decent tool to do it with!
2004 Berlingo Multispace HDI, 105000
Ross
YEEEEEEEEEESSSSSSSSSS
Unread post by Ross »
Finally got back on - happy Easter to one and all - lol
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I use the Pleiades tool and find the the angle the arm is mounted onto the strap to be very well thought out, particularly when removing Hydractive sphere's as it allows it to swing clear of obstructions. Unless the Ebay one has this feature, I'd pay the extra for a Pleiades tool.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
andmcit
x 30
Unread post by andmcit »
Don't think I'd trust using it on loads of awkward to get at spheres. The
grip actually appears to be the bolt fed in sideways against the sphere in
a pinpoint position the ring being purely alignment. Combine this with a
very small brace link and it all looks like it's relying on the single bolt with
the threaded area on the handle taking all the strain.
Nope, no good! I'd spend your hard earned elsewhere!
Andrew
slim123
Unread post by slim123 »
Looks to me that it's a bit reliant on the bolt going through the side biting into the sphere to get a grip, poss ok on the fronts but I cannot see it working too good on the rears.
My old (pleiades) tool has removed hundreds of spheres over the years, so I guess that if you got yourself one, removing 10 would be a doddle. Plus you could sell it on ebay afterwards and get most of the cash back.
Regards
Slim.
Xaccers
x 185
Unread post by Xaccers »
You could make a B&Q special for under £10 :)
DIY sphere tool
ellevie
Unread post by ellevie »
I've heard consistently good reports about this little baby from Machine Mart,
http://www.machinemart.co.uk/shop/produ ... ter-wrench
Has anybody ever managed to break one of these ?
andmcit
x 30
Not yet, but I've been trying hard!!
Still bought a Pleiades wrench though - least with that you can larup seven
bells out of it without fear of anything ending up embedded in your forehead...
Andrew
dan_the_v8man
Unread post by dan_the_v8man »
yes i've managed to break one
but to be fair and to its credit, it wasnt on a sphere and it had a scaffold pole over the handle which is to be expected really, but when desperation requires, such things must be tried
Dec 94 Xantia LX 1.9 TD 116k - My first car :D
uhn113x
x 3
Unread post by uhn113x »
slim123 wrote:Looks to me that it's a bit reliant on the bolt going through the side biting into the sphere to get a grip, poss ok on the fronts but I cannot see it working too good on the rears.
I agree - it is a very poor design indeed, IMHO. The entire strap should be gripped. The bolt will get burred so it will not unscrew.
I made one from scrap about 10 years ago, based on the Pleiades one - works just fine.
[Edited - Plieades transposed]
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
David W
Unread post by David W »
As DickieG says I would say the Pleiades tool or a very close copy is worth the money. The problem that is sometimes missed with the chain types is that they flex through a few degrees so you lose some motion and can't shock them with a hammer very well.
The handle angle is perfect on the Pleiades one as mentioned.
I have broken a link on the heavy chain type in the image.... using a length of scaffold pole on the end trying to do a pig of a BX rear sphere. When it went so did most of the skin on my hand.
David
2009 C5 HDi VTR+Nav Tourer
2006 C3 HDi Desire
LeeDJC
Thanks for the help :)
I think I'll opt for the pleides option. Sounds like it's worth paying the extra £££ for.
x 8093
LeeDJC wrote:Thanks for the help :)
Yes, it is the only one that will shift the Activa Balancing Sphere and Rear Hydractive Sphere. They then practically fall off. Those two are particularly difficult due to their location and the very close vicinity of pipes and other impediments.
