Hi, I think I may have got the problem solved. I have replaced my nearly worn (just before the warning sensor probes)brake pads. Maybe as train of thought goes, the extended brake piston was letting fluid past and causing the peddle to pulsate? Who knows?
Will keep you poseted.
Paul
Dredded Xantia Pulsating Brake peddle.
wrinklet1
AndersDK
akojic
AndersDK
