Interesting ZX
rossnunn
Interesting ZX
http://post2.auto.163.com/car/citroenzx ... list0.html
I do very much like the Front & Rear lights.
- x 8431
It'll be a Chinese Copy then
Looks rather smart, apart from the decals. I take it this is the version of the ZX they still make in China. Looks like a "facelift" version the French never did.
Any details of the engine? I didn't recognise it as a current PSA engine despite the chevrons on it.
Ross_K
- x 110
AndersDK
Its the TU5JP 8V engine which is made for ZX models in China. It found its way into the Saxo as well as the TU5J4 16V engine. The Xsara also came with the TU5J4 engine and so did the recent C2/3 models.
TU engines have the characteristic location of exhaust manifold at front of engine.
http://www.citroen-pr.net/catalogues/il ... 20B100.gif
Another development since the first TU types is the location of the cat converter immediately under the manifold and the usage of 2 lambda sondes :
http://www.citroen-pr.net/catalogues/il ... 56J15A.gif
Anders (DK) - '90 BX16Image
Sl4yer
Kowalski
Xaccers
- x 188
Don't they use RHD in Hong Kong?
DIY sphere tool
DIY sphere tool
jeremy
- x 3
Interesting that they don't seem to have done any re-skinning - which I would have expected after all this time as the dies would have worn out. This is the reason for minor alterations in a car's life - as its virtually impossible to replicate the originals precisely - and shaving corners off etc solves the problem.
I wonder how long it will last? Will it live as long as the Hindustan Ambassador (Formerly Isigonnis suspended Morris Oxford which first say the light of day in about 1953)
jeremy
uhn113x
- x 3
FrenchLeave
rossnunn
- x 8431
They're not Activa Alloys.Kowalski wrote:Those alloy wheels look strangely familiar, just like the set on my Xantia...
I wonder whether the moulds for the Activa alloys are in china now, so can you buy Activa alloys new?
If you want some they're still available according to pr.net. Part No. 5402 A1 at a whopping £138 each
They often come up very cheaply on e-bay.
rossnunn
philhoward
Having just come back from working in China for a month, i've seen a few of the AXCs with 1.4i or 1.6 16V engines (according to the badges..); some are also badged as ZXs!
The new taxi to have apparently is a Citroen Elysee VIP..the front is a cross between a late ZX and early Xsara, but its a 4 door Saloon (a la 306 Sedan in the UK) and with......
(wait for it)
100mm extra wheelbase (read rear leg room) in the form of the largest B pillar ever seen! Comes with the 1.6 16V engine again...
(wait for it)
AndersDK
no -rossnunn wrote: Anders I've seen those front CAT's mounted in the downpipe on Saxo's/106's, never knew why - I assumed it may have been a bigger cat there for wouldn't fit in its usual place?
Or maybe tighter emission control?
I believe its purely in interests of making the complete power unit as compact as possible.
That would also ease the assembly on the production line - cost effectiveness - the demon of our time
Maybe it gives a better cooling of the (very hot) running cat too.
Catalytic converters are surprisingly small & compact up to 2L engine size. It aint worth distinguishing between different engine sizes unless you are down below 1L in engine size.
A Catalytic converter is nothing but a cavity with an internal surface helping to oxidise the exhaust gasses. And of course an external protective grid against the very hot temperature.
