LDS Level
curly
LDS Level
Unread post by curly »
Can anyone help? just been check my fluid levels and noticed my Lds level looks low but it has no MAX or MIN marks the tank can anyone tell me how much should be in there
:roll:
Curly
x 94
Unread post by citronut »
what car is this and what is LDS
regards malcolm
AndersDK
Unread post by AndersDK »
malcolm - that would be a C5 with the successor of LHM fluid - the LDS fluid. If not already done, I believe you should start stock this fluid as well as LHM :idea:
- because Citroen customers knows where good service are to be found :wink:
Anders (DK) - '90 BX16Image
FrenchLeave
Unread post by FrenchLeave »
Malcolm,
When are you going to open a branch in Lincolnshire?
x 1052
Unread post by wheeler »
Remember the fluid is checked with the suspension in the LOW position. There is a small line at the front of the resivoir just above the seem,this is the line to show that the suspension is on the level.
x 94
sorry i just havent been under a C5s bonnet yet and am not particuly looking forward to doing so either,as im still trying to keep as many customers on the road with BXs and DERSHES and at a push if i realy have to the odd XANTIA,thats about all my tinny brain can coppe with
regards malcolm
x 8217
citronut wrote:,thats about all my tinny brain can coppe with
regards malcolm
You're selling yourself a bit short there Malcolm :D :D :D
x 94
blush blush,well maybe i think we all might know more than we think we know
regards malcolm
curly
LDS Level
Thanks everyone, sorry forgot to say its a C5 anyway when I checked the fluid the suspesion was in low and the fluid was half way between the seem and empty does this need topping up and if so were has the fluid gone :?: have checked for leaks but none found I was told the system is self lubing so does it use the LDS to do this
AndersDK
I believe you need to let the car rest over night while suspension set to low. That is to make sure all spheres have relaxed their LDS filled cavities to the reservoir.
Topping up over the needed limit means spillage, nothing else.
