Hi, anybody had any experiences where water was collecting under the single rear seat well. Can't see where it's coming in from but it's like a mini swimming pool under there!
Any pointers would be appreciated.
Cheers.
Simon.
Xantia- water under rear seat
SimonT
Saxo 1.5 XD 1998
(previously owned Xantia 1.9 TD sx 1995)
jeremy
andmcit
- x 30
np
If its an estate,then most defo the tailgate membrain.I had this a few times till i fixed it for good.Water will come in around the rear wiper seal,& drain out at the bottom of the tailgate.But if the membrain inside the tailgate loses its seal,then the water will go straight in the boot under the carpet,& run along the load bay floor channels & under the rear seats.
If it is an estate,& it is the membrain,i did a post on here a year or 2 ago about the best way to cure it & what sealer to re seal it with.
53`406 est SE Hdi 140,110k
jsgarth
I had this problem with my Xantia a few weeks ago. My mechanic told me that it is very common and caused by the drain from the sun roof being blocked.He recommended, that I push a length of wire (I used a thin knitting needle) up the drain. It is easy to find under the nearside rear wheel arch, a small plastic pipe protrudes from the top above the wheel. You can feel it, I could also feel the mud caked around it!! A few prods with the needle and I got a cup full of cold water up my sleeve. I could then pour a pint of water into the rear of the open sun roof and watch it pour from the drain. Atrotious weather has followed without a drop of water finding it's way under the seat!! I hope that you can be as lucky. If it is the off side it does not look as simple to get at it from under the car, but I was told thast I could push a thin piece of wire from the drain at the rear of the open sun roof. Thankfully it has not been necessary.
Good Luck!!
Good Luck!!
JSG
andmcit
- x 30
AndersDK
SimonT
Ok thanks, I'll have a look tomorrow (weather permitting!)jsgarth wrote:I had this problem with my Xantia a few weeks ago. My mechanic told me that it is very common and caused by the drain from the sun roof being blocked.He recommended, that I push a length of wire (I used a thin knitting needle) up the drain. It is easy to find under the nearside rear wheel arch, a small plastic pipe protrudes from the top above the wheel. You can feel it, I could also feel the mud caked around it!! A few prods with the needle and I got a cup full of cold water up my sleeve. I could then pour a pint of water into the rear of the open sun roof and watch it pour from the drain. Atrotious weather has followed without a drop of water finding it's way under the seat!! I hope that you can be as lucky. If it is the off side it does not look as simple to get at it from under the car, but I was told thast I could push a thin piece of wire from the drain at the rear of the open sun roof. Thankfully it has not been necessary.
Good Luck!!
It is the nearside back seat so hopefully will be that side drain too. Cheers.
I love this forum!
Saxo 1.5 XD 1998
nipper123
AndersDK
steelcityuk
- x 8093
Yes, very, very possibly and the foam under the carpet will allow it to creep up to the seat well. Had it happen.steelcityuk wrote:What's the possibility that it's getting into the heater past the scuttle panel then running into the back footwell?
Steve.
Also, another place it can get in is through the rearlight clusters. All the tailgate water runs down over the tops of the clusters and if the gaskets are not perfect, water will run in the boot and then into the rear seat trays. I cleaned the gaskets and smeared them with silicone grease. Seems OK now.
next time you lift the tailgate on a wet day, just see how much water runs down over the lights!
