Xantia rear height corrector
ukmobileman
Unread post by ukmobileman »
this is the second one i have fitted (not the same car!)on the rear, so you'd think i would have remembered where the pipes go, but with a week having passed from removal to fitting the new one, i have forgotten!!! :shock:
the corrector is all bolted on and mechanical links on , the return pipe is on and the single metal hydraulic pipe that can only go to the one side as there's no where else it can go,....... but the 2 the other side of height corrector , which one goes where? either will reach each hole?
anyone got a picture ?
it's a 97 xantia 1.9td estate
regards GAry
steelcityuk
Unread post by steelcityuk »
Does this help at all?
http://f1.grp.yahoofs.com/v1/0GqdRUPu2c ... t%20it.JPG
Don't think a photo of mine would be any good as it's hydractive.
Steve.
not applicable
ukmobileman
thanks Mate that helped no end.
KevMayer
Unread post by KevMayer »
That link doesn't work for me.
Did you really see anything to help you ? :-k
Cheers, Kev
steelcityuk
It appears to be dead now. Try this -
http://f1.grp.yahoofs.com/v1/UF-hRdwnvW ... t%20it.JPG
Alternatively goto the Yahoo groups, search for Xantia, goto Xantia-L group and you'll find it within files/under xantia, it's the last image.
Steve.
not applicable
ukmobileman
yep link worked ok saved and printed picture and used to connect pipes this afternoon , my xantia is up and running again :D
ukmobileman
ukmobileman
ukmobileman
err some kind of error here i kept getting debug mode when i reply and now 3 posts the same , MODS please delete this and 2 of the copies
GAry
