The "Know Your Citroen Engine Thread"
All the sticky threads from the Citroen and Activa forums have been relocated here at least on a temporary basis.
TehAgent
x 7
Unread post by TehAgent »
Well thanks go out to mugatea for this idea.
As I'm not much of a genius when it comes to car names and parts, Plus, getting frustrated with trying to read the forums and then run to the car with things like (on the left as you look at the car its a black box),
I thought it would be time to get a kind of "map of your engine" thread going, For those like me, who can not get their head around the Haynes manual. And I wanted to give something back to this community for helping me get my car sorted.
I will update this post with info and locations so its easier to find what your looking for, and if anyone can supply photos of other Citroen engines, and item names PM me and i will add them to the thread (if you can pm me that is)
Engine
1.9 turbo
Car
97 Xantia
Engine part and location code
LHM reservoir - M1 to P3
LHM reservoir fluid level indicator - O2
Primer pump - A2
Air filter housing / Box - K5 to N9
Fuel filter - I5
Dip stick and oil top up cap - H5
Alternator - D9
Oil Filter (blue part) - F8
Fuel Pump - D5 - E6
Hydraulic Pump - C7 - D8
Air-Con pump - C7 - D8 (Below Hydraulic pump)
Quick Diagnosis Checks
Turbo sluggish / slow / not working - Check black Pipes (as can be seen in photo) for cracks / air leaks / splits
Engine hard to start from cold and producing white / blue-ish smoke once started - Check Glow plugs, possibly replacement
Engine Hard to Start from warm or cold, check Fuel Leak off pipes on Injectors (Located above Glow plugs)
Strange Grinding noise and smoke / burning smell, from the front left of engine bay, Check Air Con pump clutch to make sure its not seized.
If anyone else can lend a hand with part names and locations or quick diagnosis checks would be appreciated, ill add them to the list.
Peugeot 208 active 1.6 EHDi
BMW 330i 2007
Mx5 Mk1 1990
uhn113x
x 3
Unread post by uhn113x »
Teh
What a good idea! May I suggest a few "pointer" thingies as well?
I would have done my DS IE engine, but you would need an X-Ray camera or to be able to do layers!
The engine is down there somewhere, and, despite a DS bonnet being the biggest alloy pressing used on a car, the engine compartment is full. :o
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
dan_the_v8man
Unread post by dan_the_v8man »
brilliant idea
i'll sort you out with a pic of mine as soon as possible
Dec 94 Xantia LX 1.9 TD 116k - My first car :D
andmcit
x 30
Unread post by andmcit »
Woohoo - Citroen Battleships!!
Will O7 sink the whole lot!? :wink: :lol:
Guess I could take a piccy of my '93 Xm S1 24v V6 engine bay
just to put everyone off wanting one? Spill a spanner in this engine
bay and you'll never see it again... :D
Andrew
TehAgent
x 7
i dropped a glow plug that i had just removed in mine, still not sure if its fallen out yet, lol
anyway, if any ones got any more location for bits and bobs that you can see in the photo, let me know so i can add them, and can someone send me a PM to see iv i can receive them please
BMW 330i 2007
Mx5 Mk1 1990
uhn113x
x 3
Andrew
Same applies with a DS. Even worse, it has a particular appetite for M11 sockets. :( Tying string on spanners before you use them is not just in jest!!
Teh
Was it the glowplug on the cambelt side of the engine? Even though you could not find it, the very first motorway you use, out it will come on to the road. :o
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
TehAgent
x 7
yep, it was the cam belt side, it slipped down between the engine and the alternator
ho and happy new year all
BMW 330i 2007
Mx5 Mk1 1990
x 8391
It will reappear!!
I did the same. Always happens when someone is watching :evil:
I managed to get a long flexible strip down behind and "teased" it until it fell out, or rather, fell down to a point that I could get hold of it.
I'd try, better than have it fall out at some speed somewhere where it might just do a spot of mischief otherwise...
Glad to hear all your starting problems are at an end. Nice start to 2007 :)
Homer
x 16
Unread post by Homer »
Here's the engine bay of the first Citroen I owned.
nick
Unread post by nick »
Homer wrote:Here's the engine bay of the first Citroen I owned.
Early BX 1.6 carb petrol ??
TehAgent
x 7
ill upload it to photo bucket, and add it to the first post, with a grid on it, if you know any of the parts once the grid is on it, then ill add them as well once you let me know
also, what car is it? IE: model / year / engine size / type
BMW 330i 2007
Mx5 Mk1 1990
Homer
x 16
It was indeed, a Mk1 BX16 RS. With the PRN dash.
Image Image
Quite an easy car to work on really, compared to the Xantia.
TehAgent
x 7
that steering wheel reminds me of the old Citroen DS (please note, the cit DS is not a games console :P)
BMW 330i 2007
Mx5 Mk1 1990
nick
I've got one of those, its a Jan '86 C reg in red. I bought it when I was a student in 1993 and it was my everyday car for a few years. Its in storage in a barn at my mum's in Lincs, been off the road since 1999 unfortunately, with leaking hydraulic & fuel pipes and a very badly worn clutch. I've got all the parts to fix it, just not the spare time or the inclination at the moment.
rossnunn
Unread post by rossnunn »
great idea & so simple - now why couldn't Haynes do that?
