My car 2001 Xantia HDI 110 has an intermittant fault on the brakes. On light braking it sometimes feels like the ABS is kicking in, I suspected a wheel sensor, but Citroen Manchester said if it was that the ABS light would come on (it doesent), they then said a caliper might be sticking, is replacing this this a big job ? or is a service kit available ? I'm quite capable with a set of spanners (built a kit car once) but the hydraulic system scares me a bit, All they want to do is keep throwing parts at it (at my expense) til' the problem goes away, and I'm not prepared to pay their labour charges for changing parts I dont need. Anyone out there got any ideas?
Paul
Xantia Brake problem
Hurdsey
Xantia gone, now got a
Renault Laguna 1.9 Dci Sport tourer
2000 Westfield SEIW 175Bhp
- x 1238
- x 94
sounds to me like air in the brake system,try bleeding the brake all round first,and this is very easy with hydraulic citroen,as the presure is there all tje time if the engine has been run,so you just open each kniple one at a time press the pedle wait for a good steady flow of citro blood to come out ,then shut the kniple,air in the brake system is usualy caused by the regulater shere dumpping it gas into the system,so if it is ticking frequently replace that at the same time
regards malcolm
regards malcolm
jeremy
There are several threads on this subject.
I agree with malcolm - could well be gas in the system and the accumulator sphere is the most likely culprit. You can test it by running the car at normal height for a couple of minutes to let it stabilise, thn turn off the engine and sit in the boot. The car should drop a long way then rise again (powered by the accumulator) after about 30 seconds. If it doesn't then the accumulator sphere is suspect.
You may be able to get some of the gas out by 'Citroebics' - raising and dropping the car fully a number of times. This will NOT clear any gas that has got into the brake 'limbs' but will clear it from the circulating bits.
A defective accumulator usually is accompanied by rapid regulator cycling (5 - 10 seconds.) If the car is raised fully this frequency will drop as the suspension spheres function as accumulators.
The accumulator is vital for the proper fumnction of the ABS system. A life of between 2 and 4 years is normal - but I had a replacement one fail after 18 months and a very small mileage on my BX this year.
jeremy
slim123
Paul.
Hows the LHM, I would suggest an LHM change is due, if the car has "cheap" LHM then this sort of problem does happen, change the LHM but only use Castrol or Total, the other brands, whilst up to spec, are a little on the thin side.
If it was air in the brakes, you would be getting a delay, on and off, not much but enough to make you poo yer pants in a traffic jam.
Regards
Slim.
Regards
Slim.
Hurdsey
Wow so many replies so quick thanks guys.Peter.N. wrote:Do you mean that the pedal is pulsing or brakes shuddering or that it feels as though the brakes are being released?
The pedal is pulsing and it does feel like the brakes are being released, but with a bit of a shudder iyswim, also if I yank on the handbrake it slows as it should, which seems to rule out a disc/pad /wheel bearing problem.
The LHM is original, I have topped it up a couple of times with genuine (supplied by Citroen) Total LHM.
I'm usually quite 'light' on the brakes, my last car a ZX did 60.000miles in 4 years without a pad change, this Xantia has had, nearside caliper, offside wheel bearing, pads and discs, all on the front, I'm beginning to think its time for a change, C5 anyone
edited to add
Oh yeah I have tried Citarobics, I have been thinking lately that the suspension is getting firmer than it was, and have suspected that it may need new sheres, is the accumulator sphere specific to the brakes or linked to the suspension and where is it ?
john alexander
jeremy
The accumulator is on the regulator - first component after the pump if you follow the piping (one of the outlets - the other is the steering.)
Your Xantia has a 2 outlet pump - the major one (6 cylinders) feeds the steering, the other one (2 cylinders) feeds the brakes and suspension. All is fine if the accumulator is working as this holds up to 1/2 litre of high pressure LHM - so there's plenty to draw on when you operate the brakes.
If it goes flat - you're down to the small pump output which comes in pulses. What may be happening is that you apply the brakes - power comes from the pump and starts to compress the gas in the system, but not much by way of brakes - so you press a bit harder, open the valve more, pump output catches up and suddenly the brakes apply hard.
This may be compounded by the spring under the pedal (see other posts - this is another subject)
jeremy
uhn113x
- x 3
It is a reservoir or storage tank connected to the entire hydraulic pressure line, and situated lower centre front of engine.Hurdsey wrote:.... is the accumulator sphere specific to the brakes or linked to the suspension and where is it ?
Just like a suspension sphere without the damper.
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
Hurdsey
I've just been out for a short drive and guess what?
The front pad wear indicator light has just started to come on when the pedal is pressed, so this weekend it,s gonna be new pads and bleed, then we'll see what happens next, do i need a special tool to push the piston back ?
Malcolm
Haynes manual dos give a specific Citroen Tool number but also recommends flat bar as an alternative and turning piston in clockwise direction when pushing back in. I asked this question a week or so ago as to why rotation was req'd. I've done the job on two Xantias improvising with bar to replace pads and handbake cables with no problems.
Malcolm
'98 Xantia Estate LX - RIP 13/08/16
'08 Renault Trafic 115dci
- x 1238
Hurdsey
jeremy
I've always managed to push my BX ones round with the end of a screwdriver, but in fact the squared slots are meant to fit the shaft of a mechanics square shafted screwdriver.
http://www.machinemart.co.uk/product.asp?p=040213010
jeremy
uhn113x
- x 3
