I attempted to change the rear discs and pads on my 94L ZX Td Volcane yesterday, and had a bit of time with it. 7 hours just to put the car back in a worse state than it was when I started...!
Got the discs and pads off no problem (surpised as I expected everything to be seized to kingdom come). However, I found that I could get the brake caliper piston back in (tried my usual trick of 'gently' pushing back with a G-cramp, no dice).
I think the caliper is probably seized, but I wonder if I'm missing something. I have a Haynes manual somewhere, but can't find it presently, and have almost no experience with rear disc brakes, especially those with that kind of handbrake mechanism (my old Subaru used to have a kind of disc/drum arrangment on the back).
Anyone one know if I need to back off the handbrake, or free off some kind of auto adjuster to get the piston to move again? The piston had definitely moved 'cos in my b*ggering about I managed to get it to come further out than it was when I started (hence preventing me from re-fitting the old brakes to keep the car drivable - ho hum).
I'm obviously cr@p. Please help me
- Ian.
