citroen-pr net help
john alexander
citroen-pr net help
Unread post by john alexander »
Hi , could I ask one of our members to look up pr net for the air con hoses which connect to the compressor. I.have a goosed harrison 1135253 which has screw on pipes but some have a harrison 1135290 which has pad fittings . i would like to see if the pipe set up can be changed to give me more choice. Yes I know it helps if I tell you the car , it's a xantia 1.9 td 1996 VF7**************[VIN obfuscated, can be read by forum staff]. THANKS IN ADVANCE JOHN.
AndersDK
Unread post by AndersDK »
As I understand the parts listing and notes - you will have to choose either screw or clamp fittings on both compressor and hoses. You can not mix the 2 types of fittings.
That said - either type A/C setup should readily go into a MkI 19TD Xantia.
http://www.citroen-pr.net/catalogues/il ... 40601B.gif
0290 06 640601B AIR CONDITIONED COMPRESSOR DETAIL DIESEL XU ET REFRIGERATION
7/13/2006 2 AIR CONDITIONED COMPRESSOR DETAIL 0290 06 6406 01B
DELPHI FRANCE
A) COMPRESSOR (HARRISON) FOR SCREW UNION
B) COMPRESSOR (HARRISON) FOR UNION WITH CLAMP
http://www.citroen-pr.net/catalogues/il ... 40821E.gif
0290 06 640821E FREON TUBE - FIXING DIESEL XUD9 ET REFRIGERATION OU DIESEL TURBO XUD9SD ET REFRIGERATION OU DIESEL TURBO XUD9TE ET REFRIGERATION
7/13/2006 2 FREON TUBE - FIXING 0290 06 6408 21E
- DIESEL XUD9 AND AIR CONDITIONING OR DIESEL TURBO XUD9SD AND AIR CONDITIONING OR TURBO DIESEL XUD9TE AND AIR CONDITIONING
01 6457 RY 01 FREON TUBE
- TURBO DIESEL XUD9TE AND AIR CONDITIONING UNTIL RPO No. 07531
SEE A
- DIESEL TURBO XUD9SD AND AIR CONDITIONING
SEE A
SEE A
01 6460 J7 01 FREON TUBE
SEE B
SEE B
SEE B
01 6460 J5 01 FREON TUBE
- TURBO DIESEL XUD9TE AND AIR CONDITIONING SINCE RPO No. 07532
02 96 170 901 01 FREON TUBE
- LEFT HAND DRIVE AND AIR CONDITIONING UNTIL RPO No. 07482
02 6457 YX 01 FREON TUBE
- LEFT HAND DRIVE AND AIR CONDITIONING SINCE RPO No. 07483
02 96 170 902 01 FREON TUBE
- RIGHT HAND DRIVE AND AIR CONDITIONING UNTIL RPO No. 07482
02 6457 YV 01 FREON TUBE
- RIGHT HAND DRIVE AND AIR CONDITIONING SINCE RPO No. 07483
03 6457 RX 01 FREON TUBE
- DIESEL FUEL AND AIR CONDITIONING
SEE A
03 6460 J6 01 FREON TUBE
- TURBO DIESEL XUD9TE AND AIR CONDITIONING UNTIL RPO No. 07482
SEE B
03 6460 J4 01 FREON TUBE
- DIESEL FUEL AND AIR CONDITIONING SINCE RPO No. 07483
SEE B
04 6457 S0 01 FREON TUBE
- AIR CONDITIONING UNTIL RPO No. 07482
04 6457 YS 01 FREON TUBE
- AIR CONDITIONING SINCE RPO No. 07483
Anders (DK) - '90 BX16Image
john alexander
many thanks anders but when I try to print the pictures off I only print part of the view as its too large , honest I'm better with a spanner. regards john.
bxbodger
Unread post by bxbodger »
Why not register yourself with PRnet? You don't need to be a dealer, just make up anything for a company name and you're registered. You can also change the size of the pictures then as well. Worth it's weight in dead spheres....... :)
john alexander
already have but too thick to find my way round it and have now forgotten my password.
AndersDK
Save the image on your PC - then edit the size in any image editor (paint/imaging/kodak etc..) - and print it out 8)
jeremy
Unread post by jeremy »
My printer (Canon all in one) came with a program called 'Easy Web Print' which works with Internet Explorer and organises nice prints for you - columns for long documents, fast print (uses less ink) previews etc.
It doesn't seem to work with Mozilla Firefox but this has its own version instead which is similar.
jeremy
john alexander
Hi checked prices of aircon hoses at main dealer today , depending on type either £343.76 or£282.22. but managed to find correct compressor in FALLONS COATBRIDGE for £45. In case anyone needs a harrison 1135290 Pad fitting ALEX McMEECHAN at RAVENSTRUTHER near LANARK has a nearly new one for £40. by the way RAVENSTRUTHER is pronounced RENSTRIE . Regards john.
x 1431
"ALEX McMEECHAN at RAVENSTRUTHER near LANARK"
Which is only about 5 miles from my house, so I can collect if necessary....!
john alexander
Hi richardw wish I'd known that , could have sent you round to check it , would have saved me a run from livingston.
