I've had an ongoing problem since I got my Xantia last Christmas which I've posted various threads about but still not cured. Through process of elimination I have now come to the stage where it my be internal leakage.
The symptoms are;Regulator cycling at 6-16 seconds apart
Front suspension drops down nearly to bump
stops after 5 minutes
I don't mind the front dropping but it is the regulator cycles that worries me because the Accumulator sphere is obviously not being pressured up.
Points to bear in mind;Its had 2 new accumulator spheres
I've done lots of citerobics
It had a new regulator last year
and a new hyd pump before that
I've reseated the ball bearing in the regulator
It's had an LHM change
and remember it's NON antisink
I believe, looking at all the above bits that were replaced by the previous owner that this has been a long standing problem!
Someone briefly mentioned the other day about checking for internal leakage. Is it just a case of disconnecting return pipes? if so where.
Your help would be gratefully appreciated
regards
davetd
