Any experience on Dispatch vans out there?
The lcd odometer / trip display packed up a while ago, but I assumed that was just an electric connection behind the dash so left it alone. Now the speedo has stopped working - just stuck on zero. Apparently it stopped and started a couple of times before dieing.
Anyone know whether the dispatch speedo is electrical or mechanical?
Anyone had the dash apart before - I have visions of fighting with air bags etc.
Cheers - Jez
HDi Dispatch Speedometer and Odometer
paulstow
Jez
'00 Xantia 2.0HDi
'01 Dispatch 2.0HDi
'01 Jaguar XKR
'68 MGB roadster
'00 Xantia 2.0HDi
'01 Dispatch 2.0HDi
'01 Jaguar XKR
'68 MGB roadster
- x 1239
If its new enough to be HDi then I think its fair to assume that it would be electronic. It will be driven by a sensor somwhere, probably on the gearbox near the transmission. Either the sensor itself has failed or you have a defective connection. Hopefully someone who has had the problem or knows where the sensor is will post.
If the odometer has packed up independently there is a good chance that the actual instrument is faulty.
