dodgy compressor
john alexander
dodgy compressor
Hi there, last week i replaced my aux belt and tensioners , xantia 1.9 td 1996 but have noticed the noise I thought was the idler is really the air con compressor. It screeches like metal to metal when I start the car, this lasts about a minute then quietens down .The belt gets hot but the a/c still works .answers please on a stamped addressed compressor. Ps just noticed a famous vodka maker is running a competition. Win the life of a czar. Somehow having a mad monk sleeping with my wife and being shot in a cellar in Ekatrinaberg doesn't seem much of a prize .! but then maybe thats just me. regards john.
- x 1238
Kowalski
When the air con is off, the pulley on the compressor is just an idler, so it has no reason to slip UNLESS the bearing is causing friction...
I've replaced a bearing on a Delphi / Harrison compressor, both the Sanden and Delphi use non standard bearings, there is a post somewhere or other on here about my replacing it....
http://www.frenchcarforum.co.uk/forum/v ... hp?t=19794
Enjoy.
Enjoy.
john alexander
Kowalski
There might not actually be a nut at all.
There are two different types of clutch on the Sanden compressor (I'm not sure whether the Harrison has both types of nut), one has a nut the other does not. They both require "special" tools to remove, the ones with nuts need a puller which screws into the clutch and has a bolt screw into it to pop it off (like mine), the other type need a proper puller, which looks much harder to make.
I have a manual for the Sanden SD7, in fact its on the net....
http://www.sanden.com/support/pdf/sd7servicemanual.pdf
The Harrison compressor similar, they're not identical but they seem to be put together in the same way and work in the same way too
Check this thread for a photo of a Harrison compressor (a photo of part of it at least, access isn't easy), and whatever you do, if the label on the compressor is dirty, be careful how you clean it because the part number is very easy to clean off it....
http://www.frenchcarforum.co.uk/forum/v ... hp?t=20107
