Has anyone got a picture of this when installed mine has fallen off and I cant find the screws anywhere?
What screws do i need to re-fit? Is this a trip to B&Q?
Thanks, gav425
Xantia Driver Seat Height Lever
PicassoPigeon
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
125,000 miles
davetd
andmcit
- x 30
It's loose and about to fall apart like Gav's! Instant MOT fail too as it'sdavetd wrote:Sorry to hijack your thread but while were on the subject my height lever won't stay in position it just drops back to lowest. Can they be tightened?
davetd
dangerous - the seatbelt anchoring is on the seat which isn't secured
properly! I had this on a newly ebayed Xantia and all became obvious
once I took the plastic cover off the side of the seat.
It's held together with small torx head bolts that thread through the
lever adjuster plate and into the lower frame of the seat. They'll be on
the floor under the seat somewhere - have a good prod about - things
don't simply disappear!
Andrew
- x 1477
AFAIR they are M4 bolts. They will probably be under the seats - mine were, and this was despite that fact that someone had already been there and replaced the original screws with smaller through bar (which had sheared off!).
ISTR that fitting it back together is a bit of a challenge - I think I put one screw in with it at high then pushed the lever down against the spring to get the other in.
ekaftan
- x 8
I have a simmilar problem, although in my case it neither stays up not down.davetd wrote:Sorry to hijack your thread but while were on the subject my height lever won't stay in position it just drops back to lowest. Can they be tightened?
davetd
Is it a known problem?
Or do I just dissassemble and check whats broken?
- x 694
Most likely all that has happened is the two bolts that hold the clutch in place on the mechanism have fallen out ! This happened on my Dad's Xantia - when you'd sit in the seat it would go down and then it would go up again when you got out - it wouldn't stay at any position.ekaftan wrote:I have a simmilar problem, although in my case it neither stays up not down.davetd wrote:Sorry to hijack your thread but while were on the subject my height lever won't stay in position it just drops back to lowest. Can they be tightened?
davetd
You'll need to take the seat out to fix it but once its out and you remove the adjustment mechanism on the side its a relatively easy job to fix! The two bolts just need replacing, but it can be a little bit fiddly figuring out the correct "timing" of the mechanism to allow the adjustment to work over its full range. (Roughly - the control stalk should be able to swing between horizontal and vertical)
Regards,
ekaftan
- x 8
Most likely all that has happened is the two bolts that hold the clutch in place on the mechanism have fallen out ! This happened on my Dad's Xantia - when you'd sit in the seat it would go down and then it would go up again when you got out - it wouldn't stay at any position.Mandrake wrote:
Regards,
Simon[/quote]
Thats exactly the way its happening... the control does move, though. I'll check in a couple of days, now that its againg my car (wife now will drive the 2002, of course
thanks.
- x 694
Yep, the control still does move with the seat height - the spring that lifts the seat is still attached, as is the control lever, its just the clutch that locks the height in place becomes unbolted...
Regards,
Regards,
- x 1477
