Hi All,
I'am looking to buy a 306 hdi. I know the cambelt and pulley(s) need changing need to ask for some questions:
1. Which pulley should be changed. What I mean is - is there just the one pulley to change - or is there more?
2. Also where to buy this from and how much would it be. Any idea on labour? Should the water pump be changed too?
4. What mileage / age to change the pulley(s) / tensioner?
5. Does the 306 share the fuel (lift?) pump problem as the 406 hdi?
6 . What about the ticking injector issue - how to check for this?
7 . Anything else to look out for?
8 . Does the Meridian have sports suspension (phase 3)?
9 . Is the hdi as reliable as the old xu9 td at higher mileages?
Thanks all for your help.
looking for a 306 hdi
shezads
Found my Alfa at Last!
04 156 2.4 JTD SW Veloce (Pics coming soon)
In the family:
W 306 HDI
M 306 TD
In the family:
W 306 HDI
M 306 TD
- x 1499
Cambelt may be due at 72k or 100k miles, so on a later low mileage car is may well not be due yet.
The Crankshaft pulley - it disintegrates.
New one is about £80 from GSF. It will be off at the same time as the cambelt, so it can easily be changed then. Otherwise it only takes 1/2 hour. Water pump is preferred at same time as cambelt, otherwise the cambelt will have to come off again later.
See above. The tensioners are very good on these engines - I'd inspect with belt off and only change if rough / tight. Unlikely you will be running the car to a second belt change (200k?)
Possible - depends on the injection system fitted. No easy way to tell (till it stops!). New pumps are now cheap though, and easily fitted.
It's cleary audible in the 2500 - 3200 rpm then suddenly stops. My mate's (at 150k) is like this - doesn't seem to do much other than rattle a bit!
Clonking rear suspension (sub frame mounts), leaking matrix, U/S A/C - will need new pipe and evaporator (£300 +), bottom of radiator leaking.
Dunno
There's plenty of Xantias on e-bay in the 130k + range, so I'd guess so - as long as it's never been fed petrol!
Dunno
shezads
