I only ask as I have an intermittent loose connection/internal break in the wire loom where these two meet and I’m trying to work out which has the problem. Symptoms are, every now and again, engine will rev up and down (almost stall to about 2000 rpm) when idling. When driving you can feel car slow slightly and then pick up. Only happens every once and awhile.
I’ve noticed if I slightly move/wiggle TEMPERAT PROBE and POTENTIOMETER wire/s engine goes back to normal.
Cheers
Steve
