98 Xantia TD
dazzle
98 Xantia TD
Unread post by dazzle »
The radiator blew on my 1.9 TD Xantia and I cooked the engine!! :roll:
I need a replacement engine and have been told that the 406 engine will fit.
Is it a straight replacement??
Thanks for any advice. :)
KP
x 27
Unread post by KP »
It should be. its made easier if itsof the same age regardng the immobilser and the like
Try ebay as theres one on there at the min for £150 iirc.
x 1240
Unread post by Peter.N. »
Any 1.9 XUD engine will fit ...eventually, but there are a number of differences. Firstly check the camshaft, some have a drive taken from the end for a vacuum or power steering pump. Also aircon type are different from non aircon as the alternator is in a different place. The best advice I can give is to take some photographs of your engine to check against your potential replacement. One from a conventionally sprung car may not have provision for mounting the hydraulic pump.
davethewheel
Unread post by davethewheel »
would in not be easier to repair the old one, presumably if you cooked it it will need a head gasket and a skim, better the devil you know unless the damage is worse than just the head :)
f00lzz
Unread post by f00lzz »
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
