curiously enough they are nowhere to be seen right now
realising from 'the boyfriends' garbled explanations it was a big job i carried multiple jacks etc but still the scale of damage impressed even me.....
the car initially had one problem....it wouldnt go up and down....aha you cry height corrector......
so that was my first stop and yep the metal rod (rather than the plastic clip) has broken away.....anyone know if it is it possible to just fix this part (blu tack?).......or can you buy the bit of metal it should be attached to on its own?
or is an entire height corrector needed?
unfortunately he (and his mates) didnt spot the simple solution and decided to change the rear spheres (though change is perhaps to tame a word....butcher would be my favourite
so the car has two new rear spheres (im impressed) except both mountings are utterly mullared....the bit furthest back where the clip goes through looks like someone has levered it then hammered it then levered it again.....
so neither suspension unit is exactly tight in there....they have also managed to pull the gaitor of the nearside unit (i assume it would be a top idea to refit it
but the offside one has a LHM leak from the metal pipe that goes into it (should it have a rubber sealing washer there?) and it looks like there is a bigger leak (though its possibly just the one leak leaking a lot) at the other end of it........
so just laughing and walking away isnt really an option for me (my girlfriend didnt take it well when i laughed about it earlier and the cat was looking nervous about not getting to sleep on its sofa tonight
so i have come to you good people for advice.......
oh in case it matters its a P Reg 1800 16v petrol (or about £80 of scrap
Oh and i forgot to mention its vomiting lhm through a large pipe (that goes no where) on the front bulkhead of the engine bay...i assume this is some sort of overflow?
