Glow Plug Spanner
PicassoPigeon
Glow Plug Spanner
Unread post by PicassoPigeon »
Would this work on the Xantia :?:
http://tinyurl.co.uk/caol
gav425
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
x 1240
Unread post by Peter.N. »
Looks useful that, thanks.
citroenbx
Unread post by citroenbx »
Yes it does work i have one........But go to GSF for this its £9.99
Some Ebayers ask far too much .........Cheers
Life feels good just as you complete No4 Glow Plug on a ZX-TD
x 8360
If you have a Bosch pump, it is not so good. have a look on page two of this post where I report on the use of mine.
http://www.frenchcarforum.co.uk/forum/v ... s&start=15
I did not find it much better on a non-turbo Lusas equipped 205 either. :(
Sorry, not a fan..
Dave Burns
x 3
Unread post by Dave Burns »
You are much better off with a set of deep cranked offset ring spanners like these ones I use, jobs a doddle with the right tackle.
http://www.cromwell.co.uk/static/public ... s/1081.pdf
Don't fanny about with the 8mm nut on number four, just notch out the cable terminal with a pair of side cutters so it slides under the nut, you then screw the new plug in with the 8mm nut allready in place.
Dave
jeremy
x 3
Unread post by jeremy »
jeremy
Kowalski
Unread post by Kowalski »
That design of ratcheting ring spanner aren't brilliant, when you put a lot of weight on them the individual flat pieces of steel that they are made from bend and they come apart. If you do want ratcheting ring spanners you want the type where the body of the spanner is forged from one piece of steel.
As has been mentioned, the offset ring spanners are needed, that ratchet spanner simply won't go onto the difficult one on my '97 Xantia.
