Bought Xantia and have no keypad code
ekaftan
x 8
Unread post by ekaftan »
I bought a 94 VSX Xantia. Seller has no code for the kepad immobilizer. Car is stuck in 'Neutral' mode and does not ask for code anytime.
Can I disconnect the keypad and forget it? Will it ask for the code sometime
in the future? Will it stop working if the batter is disconnected?
Thanks.
Richard Gallagher
Unread post by Richard Gallagher »
Once the engine is running the keypad can be disconnected and left disconnected. The immobiliser won't ask for a code again unless it is reconnected.
There is a company who will 'read' the code logged into the keypad. I can't recall the name of them but you post your keypad (+ fee) to them, they read it and return it.
Berlingo Multispace 05 1.6 HDI
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
andmcit
x 30
Unread post by andmcit »
You can fit any keypad into the car, it doesn't matter
- the code is stored in the ECU...
Sometime in the past the keypad has been neutralised
and you don't need it now even when the battery is disconnected.
If you want to reactivate the code you'll need the original 4 digit code
or an ECU replacement ftom a scrapper with the code known and
seen to be working.
Andrew
x 694
Unread post by Mandrake »
So if the code is stored in the ECU, how does sending the keypad away to be "read" do any good ?
Regards,
ekaftan
x 8
Richard Gallagher wrote:Once the engine is running the keypad can be disconnected and left disconnected. The immobiliser won't ask for a code again unless it is reconnected.
This works even if the code is "neutral" mode?
ekaftan
x 8
andmcit wrote:You can fit any keypad into the car, it doesn't matter
seen to be working.
Andrew
Is there any danger that the code will be asked sometime in the future? for example, if I disconnect the keypad and reconnect it? or if my wife (who has another Xantia with a working keypad tries to use her code on my car 3 times?)
The car has had 3 previous owners and I know the last 2, none of which have ever used the keypad ever. First owner is non avaliable for questioning...
thanks.
(I am not in Europe, or I would send the keypad for reading. also, Xantias are not as cheap down here as they are in the uk)
andmcit
x 30
Mandrake wrote:So if the code is stored in the ECU, how does sending the keypad away to be "read" do any good ?
Regards,
Frankly, I doubt it will. I've used the SAME keypad with a series of different
ECU's and their known codes to check they worked properly on an Xm and
a Xantia, so don't think the keypad has any influence. I've got a few keypad
Xantiae that NEVER need a code inputting into them EVEN after the battery
has been disconnected and reconnected a good while later.
I'm guessing the car which is the topic of this thread is a 2.0i VSX petrol?
Andrew
ekaftan
x 8
Andrew
Yes. 1994 (orga 6471) 2.0i VSX petrol automatic.
No diesel Xantias where I live... :(
andmcit
x 30
Thought just struck me. I had the rubberised fronts of the keypad wear off
my TD 1.9 Xantia thus giving anyone a reasonable clue as to which numbers
to press so I bought another from a Peugeot in my local scrapyard and
plugged it in and it all works fine with the correct original code!!
As I said, it's the ECU that matters, and there's plenty being scrapped
around ebay etc here at the moment.
Andrew
ekaftan
x 8
andmcit wrote: As I said, it's the ECU that matters, and there's plenty being scrapped
Andrew
Thanks. Will look around for one that can be shipped overseas... (I am in SouthAmerica)
andmcit
x 30
ekaftan wrote:
Andrew
In truth there isn't really anything to worry about. I'm sure some time
through the last two owners' use the battery has beeen reconnected and
still the car starts immediately without a code being inputted - I've got a
very early 1993 VSX 16v which has had it's battery in/out a few times
now, and whilst the light may be red as the ignition is switched on the
light immediately goes to green when the ignition starter is turned
allowing the car to start!
No worries here!!
Andrew
andmcit
x 30
Andrew
I'm happy to keep an eye out for you, I'm always on ebay/visiting breakers here.
Andrew
ekaftan
x 8
andmcit wrote: I'm happy to keep an eye out for you, I'm always on ebay/visiting breakers
here.
Andrew
Thank you!
x 1056
Unread post by wheeler »
Regards,
The code is stored in the injection ECU but i believe that when the keypad is interogated it can tell you the last code that sucessfuly unlocked it.
andmcit
x 30
Must say, I didn't think it would be possible for the keypad to leave
electrical footprints for the unlock code - seems a bad design to me!!
Guess when I think about it - in the remade 'Gone in 60 Seconds' doesn't
someone actually show the code being downloaded from the cars's kypad?
Andrew
