Xantia front strut
fangy
Xantia front strut
Unread post by fangy »
Hello, I've got a Xantia 1.9TD vsx, earlier today the front passenger side strut came up through the inner wing, the car looks fine no rust or rot, it looks as if the strut broke away from the square plate/bracket that bolts it to the car up inside the front wing, Do I need to replace the hole strut or can it be stripped and this square plate/bracket be replaced on it's own.
Thanks for any help,
Fangy.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Fangy
bad luck :(
I think -
just replace the strut top in it's entirety with a good used one. I payed £20-30 for mine last time I did them.
John
andmcit
x 30
Unread post by andmcit »
commiserations - this IS my good ol' hobbyhorse:
http://tinyurl.com/omdjd
What colour bonnet are you after...?
Andrew
andmcit
x 30
Bear in mind the VSX has a different strut top to most other Xantiae as it's
pipe feed is a much larger bore diameter than the normal 3.5mm.
Damned hard to find as I've been on the lookaout for ages. Guess £100
apiece new from Citroen is the only answer.
Andrew
fangy
Thanks for getting back to me, It happened just as I was about to pull out the drive, I heard a bang, got out the car and had a look but couldn't see anything at first, so I lifted the bonnet and that's when it really went bang and the strut shot up through the inner wing, so i managed to save the bonnet, I priced a full new strut from GSF they want £142 +vat, I'll phone them tomorrow about the price of a strut top, but if it comes to it and I get one from the scrappy, is all models inter-changable, reading through the link from andmcit it would seem they are, but I'm just checking, also can the top of the strut be changed with the bottom still connected to the car?
Thanks again,
Fangy.
fangy
Andrew
How can I tell a vsx from any other model in the scrappy, is it just the bore of the pipe thats different, or is there any other more recognizable differences? after talking to the scrappy guy's on the phone, I don't think they know what models they've got.
Fangy.
Is the feed pipe the solid pipe at the top of the strut?
andmcit
x 30
Hi Fangy. That's right, the pipe is the one that attaches to the strut top angled
towards the top from the engine bay bulkhead and is about 12mm diameter.
The ONLY way to determine what scrappy's have is to ask how big the pipe
going into the strut's top actually is - it'll be abvious when you've seen one
against the other!
Vsx's will have alloys and usually the earlier models up to around P will have
a tartan pattern interior which IS memorable for the usual yard mentality... :wink:
The only other giveaway if these have been removed is the switch for the
hydractive AUTO - SPORT beside the gearleaver which some folk recon
actually alters the mode of the gearbox... :roll:
Andrew
x 94
Unread post by citronut »
acording to citroen there are 4 differant strut tops and they are model specific,and GSF did not used to just sell these on there own,i will look up pr.net and get the part No
regards malcolm
fangy
Thanks for all the info folks, I'll head down to the scrappy tomorrow and see what they've got, fingers crossed.
Fangy.
andmcit
x 30
Rightho - the following listing is for item 2 on Citroen's parts listing for all options of Left hand sphere bracket:
02 5271 C0 NFP
LEFT SPHERE BRACKET - EXCEPT POWER STEERING
+ 5271 92 (01)
02 5271 E1
LEFT SPHERE BRACKET - POWER STEERING AND WITHOUT HYDRACTIVE SUSPENSION
(+ 5271 92 (01) UP TO 7244)
02 5271 E2
LEFT SPHERE BRACKET - POWER STEERING AND HYDRACTIVE SUSPENSION
+ 5271 92 (01) TO O 6610 - POWER STEERING AND HYDRACTIVE SUSPENSION
+ 5271 92 (01) TO O 7244
02 5271 E3
LEFT SPHERE BRACKET - INJECTION ES9J4 AND POWER STEERING AND HYDRACTIVE SUSPENSION
The last two listings are the VSX sphere brackets with the ES9J4 the Activa.
Andrew
fangy
I'm totally lost with that, :?
Is the sphere bracket the strut top? and is 02 5271 E2 and 02 5271 E3 the part numbers? If so whats the difference, and could you tell me what INJECTION ES9J4 is?
Cheers,
Fangy.
andmcit
x 30
Hi - sorry, wasn't trying to confuse - it's probably why nobody ever
manages to get the right part from Citroen!! The guy in the parts dept
has as much [if not less!] idea than the rest of us...
The sphere bracket is the sphere top - the black enamelled part
that the sphere is threaded onto - there's some great pictures
in the thread:
that LeeDJC posted.
The listing you'll need to concentrate on is the:
02 5271 E2
The 5271 E2 is the part number with all the information listed below
the same part listing! The RP [Replacement Part] numbers show the
suitabilty for the rp numbers shown in that range listed.
The ES9J4 is the Activa active anti roll system that uses the same
Hydractive design as the VSX but I guess is adapted with differences
in the internal bores of the LHM oilways or whatever!!
Andrew
fangy
Thanks, you've been a great help, I'll head over to Citroen today and see what the damage is. £££.
Fangy.
x 1484
ES9J4 is actually the engine code for the 3.0 V6 - not sure why they have different strut tops.
It's not really worth buying from a scrappy unless it's a late low mileage car, or it's likely to go the same way as the one've got.
andmcit
x 30
Thanks for the correction Richard! I had a nagging thought it may be different, and as yet I've not had the pleasure of dealing with a V6 Xantia yet...
Andrew
