Continuing starting problem
Huntly
Unread post by Huntly »
:cry: '97 Xantia 1.8i 16v .60,000 mls Scotland. No previous problems with starting/running. Out of the blue, it just turns over but doesn't start.Checked forum and checked for power at fuel pump with ignition on- none. Borrowed another twin relay and it started first time. Sorted ? no -left it overnight and it again started first time but 10 mins into a run around town it died again - same problem. I'll check the second relay back in the other car tomorrow and see if it's working.Any suggestions as to next steps would be much appreciated.
x 1240
Unread post by Peter.N. »
Sounds as though you have an intermittent connection somewhere. Try running a temporary lead extrernaly to the pump, if that cures it, you can either follow the lead back to try and find the fault or make the temporary lead permanant.
