Costly mistake?
yellowperyl
Costly mistake?
While changing the nearside driveshaft oil seal on my Saxo I managed, like a total idiot to tear a hole in the bottom balljoint rubber boot, is it possible to buy this rubber boot on its own or is it as I fear a costly mistake and I will have to buy the whole lower suspention arm?
philhoward
A split in the boot isn't an MoT failure point - just that it lets dirt in which will destroy the joint in no time.
On a more serious note...try a bit of careful cleaning and try Superglue (no - i'm not kidding). Get a couple of cotton buds dampened with white spirit, clean up the split in the boot and give it a try. You've got nothing to lose!
jeremy
yellowperyl
Yes, thanks for your suggestion, I bet placing one over the top would work. Even if they don't sell universal ones, I was thinking that if I bought a track rod end and took the rubber boot of it and put it over the bottom balljoint this may work? Sure it be alot cheaper than buying a lower suspension arm. Will try the glue first though as this will probably be the cheapest option.
jgra1
- (Donor 2021)
- x 36
AndersDK
Your local Maplin/radio shack (electronics DIY) store will stock a comprehensive range of heat shrink tubing.
This is excellent as repair sheating - as it will take up exactly the form on the object it shrinks on to. Therefore it will make the repair tight and leakproof.
May cost you one or 2 trials until you learn how the tubing performs under heat.
The tubing will be in the order of £5 / 1m. Diameter (cold tubing) must be close but little more than the object it goes over. The tubing is rubber-like when shrinked.
You need an electric heatgun. A hairdrier does not supply the required heat.
Anders (DK) - '90 BX16Image
Onlinewheeler
- x 1055
8304
deian:
they mean the ball joint rubber boot not one of the drive shaft gaitors - the outer gaiter on a diveshaft is indeed a fail if its split but the ball joint dust cover isnt......
shrink rap method sound interesting - worth a go...
a couple of years back the day before an mot i noticed my outer driveshaft gaiter had a plit in it. i repaired it with super glue and cotton wool - the cotton strands and the glue bond the surfaces together very well - its been on there for 2 years and hasnt split again... yet....
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
- x 94
mezuk04
I've had two split cv boots in my time during MOT tests, although I take them to where my dad gets his lorry work done as they go back years so maybe its just for me like but Ive just been told to get it replaced sooner rather than later.
Even had a blown bulb during the test, and I said I have a spare one so he put it in for me....I even went up on the ramps while he did the under car inspection
Volkswagen Golf 59' 1.6TD S
yellowperyl
jgra1 wrote:hi apologies for not being familiar with your model...
cant you buy the whole ball joint for £5-10?
Either screw into lower arm / or undo 3 'torx' bolts...
This is true of most Pugs and Cits until (quite) recently.?
John
Unfortunatly this is not the case on my Saxo, the arm and ball joint are all with in the same casting.
Had a look at the Maplins web site and unfortunatly they don't do a heat shrink sleave big enough, so I'm goin to try the cotton wool and glue method this morning.
yellowperyl
