1.9d to 1.9dt conversion with no ECU
karlsdispatch
Unread post by karlsdispatch »
Hi
I have a 98 dispatch 1.9d (XU eng) which needs a new head, bottom is ok. I also have a 98 Xantia 1.9td (XU eng) which has a damaged bottom end but a good head and turbo. However, in comparison, the dispatch 1.9d has a simple engine, ie no ECU and masses of electrics. What I want to do is use the head and turbo from the xantia and run it on the dispatched 1.9d bottom end. In principal it should work and the logic behind a turbo is very simple. Has anyone ever run a turbo on a NA D engine before? What were the results?
Many Thanks
Karl
dnsey
x 19
Unread post by dnsey »
It can certainly be done in principle - the earlier TDs had no ECU - but I believe that the TD bottom end was strengthened, so it's a bit risky if you intend to use the extra performance.
Have you consulted your insurers, though? Most are very touchy about such conversions these days, as they're an unknown quantity as far as they are concerned, and will sting you if they agree to insure you at all.
x 1477
You won't be able to - there will be no oil feed or return for the turbo on the block. Shouldn't be too hard to find another 1.9D engine to fit - or even a TD unit as mentioned - but talk to the insurers first - they dislike engine swaps!
karlsdispatch
Hi
Engine swaps with me and the insurers are no probs as ive put MI16's into 205's and RS turbo lumps into Orions so shouldnt have a problem. Im certain that the 1.9d block will still have, but blanked, the oil feed holes available? If not could I source it elsewhere? or make up my own from a small resorvoir, a oil cooler and a 12v pump?
If this is the only issue I should be ok? Does anyone know though if a d runs the same standard compression as a td, or is this changed by using a different head gasket?
Many Thanks
Karl
James.UK
Unread post by James.UK »
the TD engine was built to stand the added torbo torque.
Just as the autobox wouldn't take the turbo, neither will the UD bottom end for very long.. I think an XUD head is the way to go...
Simple is best, lmho.. :P :)
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
h2ocooler
Unread post by h2ocooler »
Just had a look in my Haynes manual and the non turbo compression ratio is 23:1 turbo is 21.8:1, cant see any other spec diffs other than that. Would have thought they would use the same block and just have the oil way capped off, you might have the change the sump if the turbo returns its oil direct.
Good luck and let us know how you get on.
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
srx600
Unread post by srx600 »
I thought the Turbos had extra oild jets to cool the underside of the pistons, or was this just very early XUD engines ?
weety
Unread post by weety »
i thought the con rods were strengthened as well
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
AndersDK
Unread post by AndersDK »
There are lots more differences than the compression ratio. Haynes cant be bothered as they never thought their manuals as engine reference manuals with all sorts of spec's listed.
Anders (DK) - '90 BX16Image
