front wheel bearing
davethewheel
front wheel bearing
has anyone changed a front wheel bearing on a xantia 1.9td, mine has just started to whine so i don't think it will be long untill it needs to be changed, iv'e changed a few before but not on a citroen and some can be a right bugger, i could always get a garage to do it but i'd rather do it myself as long as you can do the job with a puller
- x 1238
AndersDK
Or use an air impact chisel to push it out. My preferred method.
Unless you have acces to (or make yourself) a special puller bushing fitting exactly on the edge of the outer shell of the bearing - you can forget about using the puller approach.
Note : when removing the driveaxle (CV joint) from hub - consider undo/loosen the clamp holding the strut in the hub. This way you avoid possible damage to the lower swivel joint (easy to do
Anders (DK) - '90 BX16Image
davethewheel
