Xantia V6 Overheating
f00lzz
Unread post by f00lzz »
No nothing missing.... just the same as on mine. glad to hear you managed to solve your problem.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
x 1476
Unread post by xantia_v6 »
Stempy wrote:The Bitron cooling control module on the V6 is in the box with the engine and suspension ecu.
I finally got around to playing with the Bitron on my Mk 1 Xantia V6, and the Bitron is definitely below the LH headlight.
A bit of Servisol sprayed into the connector seems to have cured the intermittant temperature warning light, which had been getting quite frequent. The A/C seems to be blowing colder as well!
There are a couple of beefy relays in the ECU box on the RH side of the engine compartment, what system do they control? one of them looks like it has been overheating, as the plastic case has a bulge in the top.
Stempy
Unread post by Stempy »
This is purely speculation but they could be the heated seat control units. You could try unplugging them and if the seats dont get warm you have your answer.
Lexia ponce
x 1476
xantia_v6 wrote:There are a couple of beefy relays in the ECU box on the RH side of the engine compartment, what system do they control? .
They are not for seat heaters, as my car doesn't have the cold climate pack.
